    How to send a function as payload of socket notification?
    socket notificationnotificationspayloadnodehelper
    5 Posts 3 Posters 912 Views 3 Watching
      ngnijland
      Hello,
      When I receive a socket notification in my node_helper.js file I want to sent a socket notification with an object containing a function as value of one of its keys. Like this:
      const NodeHelper = require('node_helper');
      const someFunction = require('./someFunction');
      module.exports = NodeHelper.create({
        start: function () {
          console.log('Start node helper');
        socketNotificationReceived: function (notification) {
          if (notification === 'FOO') {
            this.sendSocketNotification('FOO', { bar: someFunction });
      However, when I receive this notification inside my main module file the function is not present in the payload:
        socketNotificationReceived: function (notification, payload) {
            console.log(payload.bar); // This logs 'undefined'
      Any other values (object, arrays, etc) I pass in the payload are received correctly.
      Does somebody know why the function I pass with the payload is undefined when I receive the socket notification in my main module file?
      S ? 2 Replies Last reply Reply Quote 0
        sdetweil @ngnijland
        @ngnijland I think u have to send the entire function in the packet. It can’t contain the address of anything on the other side
          ngnijland
          @sdetweil thanks for your reply!
          I don’t think I completely understand you. What do you mean with “send the entire function”? Do you mean I can’t import a reference? And should write out the function in the node_helper.js file?
            A Former User @ngnijland
            @ngnijland
            Impossible in the current MM legacy structure.
            those processes are separated and can not share function.
            2 reasons;
            • The function itself cannot be transferred through socket (JSON doesn’t allow it)
            • If the function depends on some dependencies, it will lose them.
            Anyway, if the function itself is somehow simple and has no dependency, there could be some trick.
            var originalPayload = {
              "something": "hello, world",
              "someFunc" : (value) => {
                console.log(value)
                return value
            originalPayload.someFunc("Original Execution.")
            let replacer = (key, value) => {
              if (typeof value == "function") {
                return "__FUNC__" + value.toString()
              return value
            // Encode function in payload object
            var encodedPayload = JSON.stringify(originalPayload, replacer, 2)
            console.log("----")
            console.log(encodedPayload)
            console.log("----")
            // encodedPayload will have;
            //   "something": "hello, world",
            //   "someFunc": "__FUNC__(value) => {\n console.log(value)\n return value\n  }"
            // Now you can transfer this string as payload of socketNotification.
            // this.sendSocketNotification("SOME_EVENT", encodedPayload)
            // Let's assume you got a payload through socketNotification
            var receivedPayload = encodedPayload
            let reviver = (key, value) => {
              if (typeof value === 'string' && value.indexOf('__FUNC__') === 0) {
                value = value.slice(8)
                let functionTemplate = `(${value})`
                return eval(functionTemplate)
              return value
            var revivedPayload = JSON.parse(receivedPayload, reviver)
            revivedPayload.someFunc("Function is revived.")
            CAUTION
            If the function requires dependencies (node modules, injected Object, references out of scope, …) those will be lost and it will cause an error.
              ngnijland @Guest
              @Sean
              Ah ofcourse, thanks for the explanation!
              My function does not have dependencies. I’ll use good old eval to fix this!
              My use case is that I need to use a different function based on the language setting of the mirror. These functions live in a separate folder and I import them in the node_helper.js file (together with some other arrays and objects I need based on language). For now I’ll use this solution, maybe in the future I build in a build step in my module so I can import the files directly into my main module file.
              https://github.com/ngnijland/MMM-text-clock/pull/2
