    [DEBUG] Default Weather Module with OpenWeatherMap One Call API
    openweathermaponecallapidefaultweathermodulehourlycurrentdaily
    7 Posts 5 Posters 2.6k Views 5 Watching
      lost
      Hey all, I’m trying to get a basic implementation of OpenWeatherMap’s One Call API working inside the default Weather module, mainly so I can get hourly weather data, but I’m running into some problems.
      Link to Branch.
      Files with changes inside the modules/default/weather/ directory:
      • weather.js
      • weatherprovider.js
      • providers/openweathermap.js
      • wdatahourly.njk (renamed from wdataHourly.njk, Windows is being stupid)
      Sample Module Configuration: (all included config parameters are required for the moment)
      module: "weather",
      position: "bottom_center",
      header: "Hourly Forecast",
      	weatherProvider: "openweathermap",
      	type: "wDataHourly", // wDataCurrent and wDataDaily theoretically work but currently don't have .njk files
      	apiKey: "OPENWEATHERMAPAPIKEY", // your OpenWeatherMap API key
      	lat: 40.7128, // your latitude
      	lon: -74.0060, // your longitude
      	weatherEndpoint: "/onecall",
      	maxNumberOfEntries: 12
      The module just stays at “Loading …” indefinitely. The console tab in the menu that shows up after I hit Ctrl+Shift+I doesn’t report any errors or warnings, so I’m not sure what’s causing the readings to not show up.
      Any advice is appreciated since I haven’t worked too much with in the past with JavaScript, Node.js, etc. so I’m not sure what the proper way to troubleshoot problems is.
      *edit: The module seems to be loaded just fine and the weather provider gets initialized as expected. Still not sure what the problem could be.
      console log 01
      console log 02
        lost
        minor correction, the maxNumberOfEntries config parameter is wrong, it should be maxEntries instead:
        module: "weather",
        	maxEntries: 12
          lost
          Got it working! I think I’ll just avoid dot notation from now on…
          Repo is linked below. If anyone’s looking to use this, OpenWeatherMap’s One Call API asks for latitude and longitude instead of a location or location ID. But in return, you can get not only current and daily (max 7 days) forecasts, but also hourly forecasts (max 48 hours).
          All original functionality of the module should remain intact.
          Sample Module Configurations:
          	module: "weather",
          	position: "bottom_left",
          	header: "Current Forecast",
          		type: "wDataCurrent",
          		initialLoadDelay: 0,
          	module: "weather",
          		initialLoadDelay: 2500,
          		maxEntries: 32, // max 48, set by OWM One Call API
          		showPrecipitationAmount: true
          	module: "weather",
          	position: "bottom_right",
          	header: "Daily Forecast",
          		type: "wDataDaily",
          		initialLoadDelay: 5000,
          		maxEntries: 7, // max 7, set by OWM One Call API
          		colored: true,
          Sample MagicMirror Output:
          Current, Hourly, and Daily Forecasts using the OpenWeatherMap One Call API
          Link to Branch
          Not making a pull request yet since I don’t know how the default Weather module is meant to be designed.
          • Feedy88F Offline
            Feedy88
            Hey @lost,
            thanks for creating this. I am currently building my first mirror and have issues with the weather module from the master (only showing “Loading”) and hence wanted to try yours, as I am looking for hourly data anyways.
            However, I am a total noob to git and stuff, so I don’t know how to install your branch. Could you help me out here? Much appreciated in advance.
              julien-vancouver
              Thanks for your work, ive tried using your config above and have run into two issues.
              module: “weather”,
              position: “bottom_left”,
              header: “Current Forecast”,
              weatherProvider: “openweathermap”,
              weatherEndpoint: “/onecall”,
              type: “wDataCurrent”,
              apiKey: “xxxxxxx”, // your OpenWeatherMap API key
              1. using the type: “wDataCurrent” results in “UNDEFINED”
                however if I change variable to Current, I then run into issue 2.
              2. loading. Similar to your original post, my screen remains forever loading and doesn’t load the retrieved values.
              any other thoughts or tips & tricks on how to resolve?
              • I Offline
                icemanmw
                i had the same problem and changed type: “wDataCurrent”, to type: “current”, because in the folder /home/pi/MagicMirror/modules/default/weather i found the files
                current.njk
                hourly.njk
                forecast.njk
                now is runs
                  dangarlen @icemanmw
