    Motion detection: PIR sensor vs picamera
    pir sensorpicamerapirsensorturn on
    11 Posts 7 Posters 7.6k Views 9 Watching
    • Z Offline
      ZombieDE
      Hey,
      I am currently looking for a way to turn my magic mirror on/off depending on when somebody is close to it.
      Does anyone have experience with a PIR sensor, the picamera or any other hardware I could use?
      bheplerB A 2 Replies Last reply Reply Quote 0
      • bheplerB Offline
        bhepler Module Developer @ZombieDE
        @ZombieDE I used a Picamera in my first mirror. I wrote a tutorial on how to get it set up in the tutorials section. Check it out.
        • Z Offline
          ZombieDE
          @bhepler Which picamera did you use? The normal or the NoIR version?
          bheplerB 1 Reply Last reply Reply Quote 0
          • bheplerB Offline
            @ZombieDE NoIR.
              Atheose @ZombieDE
              @ZombieDE I went the PIR sensor route, but note that it does NOT work from behind the glass. It needs to be exposed to work, which sort of sucks (and is something I should have researched beforehand).
              foxF 1 Reply Last reply Reply Quote 0
              • foxF Offline
                fox @Atheose
                @Atheose said in Motion detection: PIR sensor vs picamera:
                And what do you recommend?
                Issues With MMM-WatchDog known?
                https://forum.magicmirror.builders/post/29827
                Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                BehB 1 Reply Last reply Reply Quote 0
                • BehB Offline
                  Beh @fox
                  @fox
                  I have a broad frame and a quite small PIR sensor (this one, pictures of mirror here).
                  Currently it’ hanging behind the frame and is seeable, but I want to 3D-print a small mount, to screw it to the frame, so it’s not visible and measure IR in the area of your feet when you pass the mirror
                  So it’s possible to use a PIR sensor which is not visible directly when you have a broad frame
                  • foxF Offline
                    fox @Beh
                    @Beh said in Motion detection: PIR sensor vs picamera:
                    @fox
                    @Beh . absolut fantastic mirror! Great job.
                    johnnyboyJ 1 Reply Last reply Reply Quote 0
                    • johnnyboyJ Offline
                      johnnyboy @fox
                      @fox
                      Hi there, nice build you did… can I ask how you get the colour icons next to your text?
                      Tvmia
                        elleclouds @bhepler
                        @bhepler can you link me?
