    MMM-Remote-Control: default hidden
    default hidden moduleshidden moduleshide modulesremoteremote module configshow modulesstartup default modules
    3 Posts 2 Posters 548 Views 2 Watching
      DigiDadbod
      So I have the Remote-Control module up and running. Everything seems to be working with one exception:
      the modules I have saved in the menu to be on/off is not remembered on startup. The only thing I can think of is that I installed one module after the remote was prev installed (module page has a disclaimer about doing so). It talks about indecies getting messed up but I’m not sure what we are referring to here. Anyone have an idea?
      SergeS 1 Reply Last reply Reply Quote 0
      • SergeS Offline
        Serge @DigiDadbod
        @DigiDadbod that module’s behaviour is correct. It saves all the changes for the current run. Restarting means all settings are ready from the config.js so the MM starts with default setting, not changed by RC
          DigiDadbod @Serge
          @Serge
          Thank you for the response. I guess I am missing where the config.js controls that. Is there a setting/command for that? My experience thus far: so if I save what modules I want on/off from the RC menu and then save/restart from the RC it remembers all excecpt one module in particular : MMM-RandomPhoto.
          Action/description I refer to on RC:
          SAVE: Save the current configuration (show and hide status of modules, and brightness), will be applied after the mirror starts
