MMM-Domoticz-ext: interact with Domoticz
Thanks for making this adjustment.
I am currently having problems. I was curious about your update. So I updated the module with the MagicMirror remote module. (there is an update in the menu.)
Somehow I updated my entire mirror.
⮑ Guess what! → MMM-Domoticz-ext no longer works. (Another calendar module is now also “broken”.) But for the MMM-Domoticz-ext I received this error.So again, I’m asking for your help. But I can imagine this could be a big thing. Thanks in advance if you can manage to fix this!
pm2 logs mm ↓
0|mm | [23.04.2021 21:58.08.734] [ERROR] 0|mm | ERROR! Could not validate main module js file. 0|mm | [23.04.2021 21:58.08.796] [ERROR] 0|mm | SyntaxError: Error parsing /home/pi/MagicMirror/modules/MMM-Domoticz-ext/package.json: Unexpected token } in JSON at position 669 0|mm | at parse (<anonymous>) 0|mm | at readPackage (internal/modules/cjs/loader.js:269:20) 0|mm | at readPackageScope (internal/modules/cjs/loader.js:294:19) 0|mm | at Object.Module._extensions..js (internal/modules/cjs/loader.js:1164:17) 0|mm | at Module.load (internal/modules/cjs/loader.js:992:32) 0|mm | at Module._load (internal/modules/cjs/loader.js:885:14) 0|mm | at Function.f._load (electron/js2c/asar_bundle.js:5:12738) 0|mm | at Module.require (internal/modules/cjs/loader.js:1032:19) 0|mm | at require (internal/modules/cjs/helpers.js:72:18) 0|mm | at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30) { 0|mm | path: '/home/pi/MagicMirror/modules/MMM-Domoticz-ext/package.json' 0|mm | }
Wow, that’s strange. It seams like a more strict interpretation of the code in package.json. I validated the JSON again and made one minor change. Could you pull the code from GitHub and try again? Really hope this solves the problem.
Similar result:
pi@raspberrypi:~/MagicMirror/config $ pm2 logs mm [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option) /home/pi/.pm2/logs/mm-error.log last 15 lines: 0|mm | at require (internal/modules/cjs/helpers.js:72:18) 0|mm | at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Domoticz-ext/node_helper.js:2:22) 0|mm | at Module._compile (internal/modules/cjs/loader.js:1152:30) 0|mm | at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10) { 0|mm | code: 'MODULE_NOT_FOUND', 0|mm | requireStack: [ 0|mm | '/home/pi/MagicMirror/modules/MMM-Domoticz-ext/node_helper.js', 0|mm | '/home/pi/MagicMirror/js/app.js', 0|mm | '/home/pi/MagicMirror/js/electron.js', 0|mm | '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js', 0|mm | undefined 0|mm | ] 0|mm | } 0|mm | [24.04.2021 12:09.55.294] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [24.04.2021 12:09.55.296] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
@najtram looks like u need to do npm install after the git pull.
your log output needs a few more lines to identify the missing module
The plugin now supports basic auth for Domoticz.
It is still working great.
Why is this IMHO great plugin not mentioned (yet) on:
⮑ https://github.com/MichMich/MagicMirror/wiki/3rd-Party-Modules -
Thanks for the suggestion! I added the module to the page.
Hi @goedh452 ,
Thanks for the MM Module its great!
I’m an beginner with MM and Domoticz.
Is it possible to display texts and distances (dummy text and Dummy Distance) i use the ‘‘both’’ function on my mirror.
The distance is now grouped with the switches.
I’m using it for my water softener salt level.Mayby its somehow possible to overrule the grouped option and show defined idx numbers at the bottom.
Do you have a link on how u managed your luxaflex to work in domoticz ?
(Hunter Douglas hub) i’ve got 2 top down bottom up blinds would love to read the state on my mirror.If its not possible let me know.
gr,
Martijn
