    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 80.5k Views 16 Watching
      maxs
      Hi tanks for great module. I have a small problem with the counter today from the power consumption. this doesn’t show me the amount of use of the day. Gas and water working fine. see screenshot. Do you have a solution, or where I have to search? !!Schermafbeelding 2021-07-24 om 20.59.12.jpg
      G 1 Reply Last reply Reply Quote 0
        majsoft @Sp0nsje
          goedh452 @maxs
          @maxs
          Alle data is retrieved from the JSON response. Could you post it for the electricity counter?
            majsoft
            Hi everyone, please help with setting up customs.css
            Can anyone advise me how to change the font and icon size only for the first three rooms? (Red marked)
            I would also need to delete the dividing lines marked in green.
            I will be very grateful for more detailed advice.
            customs.css
            .domoCellState {
              text-align: right;
            vertical-align: center;
              padding-left: 10px;
            font-size: 300%; 			/* velikost čísla teploměru */
            color: #FFFFFF;
            line-height: 100%;
            .domoIconDiv {
              padding-right: 5px;
              font-size: 200%;                        /* velikost ikony teploměru */
            .domoCell {
              text-align: left;
             font-size: 200%;			/* velikost pisma popisku teplomeru - vedle ikony teploměru */
            line-height: 100%;
            .domoRoomCell {
              padding-right: 20px;
            font-size: 0%;			/* velikost pisma nadpisu room */
            Config.js
            the room numbers for which I would like to change the font size are idx 1, 8, 9
              module: "MMM-Domoticz-ext",
              position: "bottom_bar",
                apiBase: "192.168.2.80",
                apiPort: "8081",
                    updateInterval: 15,
            displayType: "room",
                      alwaysShowDashboard: false,
                      alwaysShowActions: false,
                      showButtons: false,
                             horizontal: true,
                      columnCount: 3,
                      dashboardColumnCount: 12,
                      maxTitleLength: 18,
                 rooms: [
                  { idx: "1" },
            { idx: "9" },
            { idx: "8" },
            { idx: "11" },
            { idx: "12" },
            { idx: "13" },
            Another question is whether it is possible to replace the character C with ° (character Celsius)
            G M 2 Replies Last reply Reply Quote 0
              goedh452 @majsoft
              @majsoft
              I don’t think it is possible to just change the font for the first lines. All are in the same class.
                majsoft @majsoft
                @majsoft
                How to remove the lines (marked in green) I have already come.
                using this code
                hr.domoDivider {
                  display: none;
                If it is not possible to change the font size of only the first three sensors, it is possible to run 2 instances of the module in config.js, but I do not know how to distinguish these instances in customs.css
                  goedh452 @majsoft
                  @majsoft
                  I think this is also not possible, but I’m not an css expert. Maybe others have soms ideas.
                  You could create your own module based on the code and modify that css.
                  M 3 Replies Last reply Reply Quote 0
                    majsoft @goedh452
                    @goedh452
                    yes, I’m just trying to create a new mmm-domoticz-ext-2 module, but even if I replace the text mmm-domoticz-ext with mmm-domoticz-ext-2 in all files, it doesn’t work. then it would be easy in CSS to assign a font size to each module. I’m not a programmer either. I have to follow the trial and error method
                      majsoft @goedh452
                      @goedh452 said in MMM-Domoticz-ext: interact with Domoticz:
                      @majsoft
                      I can’t get the copied module up and running, it still reports loading. Basic methods for copying a module fail. Can you advise me how to copy the module?
                          apiPort: "8081",
                              updateInterval: 15,
                                showButtons: false,
                                       horizontal: true,
                                columnCount: 3,
                                maxTitleLength: 18,
                       	     rooms: [
                            { idx: "1" },
                      { idx: "9" },
                      { idx: "8" },
                        module: "MMM-Domoticz-ext2",
                          apiPort: "8081",
                              updateInterval: 20,
                                showButtons: false,
                                       horizontal: true,
                                columnCount: 3,
                                maxTitleLength: 18,
                       	     rooms: [
                            { idx: "11" },
                      { idx: "12" },
                      { idx: "13" },
                        majsoft @majsoft
                        @majsoft
                        I found that both mmm-domoticz-ext and mmm-domoticz-ext2 work separately for both modules
                        If I enter them both at once in config.js it always works only the one that is written as the last one. Can anyone help please?
                        • 10
                        • 11
                        • 12
                        • 13
                        • 10 / 13
