    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 72.3k Views 16 Watching
      peterh @goedh452
      @goedh452
      Hi and thanks again for your efforts.
      Gauge swapping positions
      I can confirm that this occurs occasionally, on a manual browser refresh if seems to have a 15% chance of occurring. ( i did 30 refreshes. and got 2 swaps) i only see the last 2 gauges, out of the 5 that i have showing, do the swap.
      Custom Gauges
      These work well and as expected. - thank you!
      here is the config I am using:
                            module: "MMM-Domoticz-ext",
                            //header: "Domoticz - new",
                            //position: "bottom_left",
                            position: "bottom_bar",
                                  apiBase: "10.60.2.252",
                                  apiPort: "8080",
                                  //apiUser: "XXXX",              // only works with domoticz "Setup|Settngs|Website protection = "Basic auth" add the MM Ip to the "Local Networks" list to allow access with no auth, then all sensors will be listed.
                                  //apihPW: "YYYY",
                                  //alwaysShowDashboard: true,
                                  horizontal: "true",
                                  columnCount: 3,
                                  displayType: "all",     // show all switchs/lights status
                                  //displayType: "dashboard",     // dashboard
                                  //dashboardColumnCount: 3,
                                  //switchIcon: "lightbulb",
                                  weather: {
                                  devices: [ "199", "200" ],    //snake temps
                                          weatherLabel: "Temperatures",
                                          gaugeWidth: 200,
                                          gaugeWindAppendText: "km/h",
                                          rainSuffix: "mm",
                                  utilities: {
                                          utilityLabel: "Gas - Water - Elec",
                                          showLabel: false,
                                          devices: [
                                                  idx: "164",
                                                  deviceHeader: "Solar Gen",
                                                  useHeaderSymbol: false,
                                                  headerSymbol: "solar-panel",
                                                  counterTodayLabel: "Today",
                                                  gaugeMinValue: 0,
                                                  gaugeMaxValue: 2000,
                                                  gaugeAppendText: "Watts",
                                                  gaugeWidth: 150,
                                                  lineWidth: 12,
                                                  markerWidth: 12,
                                                  markerColor: "#F4D03F"
                                                  idx: "191",
                                                  deviceHeader: "PowGen/PowUse",
                                                  gaugeMinValue: -2000,
                                                  gaugeWidth: 150,
                                                  lineWidth: 12,
                                                  markerWidth: 12,
                                                  markerColor: "#F4003F"
                                  customGauges: {
                                          headerLabel: "Monitoring",
                                          showLabel: false,
                                          devices: [
                                              idx: "209",
                                              deviceHeader: "Toaster",
                                              lowerText: "Voltage",
                                              gaugeAppendText: "volts",
                                              gaugeMaxValue: 255,
                                              gaugeWidth: 150,
                                              lineWidth: 12,
                                              markerWidth: 12,
                                              markerColor: "#70db70"
                                              idx: "208",
                                              gaugeAppendText: "Amps",
                                              lowerText: "Current",
                                              gaugeMaxValue: 16,
                                              gaugeWidth: 150,
                                              lineWidth: 12,
                                              markerWidth: 12,
                                              idx: "232",
                                              deviceHeader: "Brightness",
                                              lowerText: "Manual Override",
                                              gaugeAppendText: "%",
                                              gaugeMaxValue: 100,
                                              gaugeWidth: 150,
                                              lineWidth: 12,
                                              markerWidth: 12,
                                              markerColor: "#707070",
                                  rooms: [
                                          { idx: "17", name: "Status" },  // can only show switch status,, breaks if temp. in room?
                                          //{ idx: "14", name: "Testing" },
      – Peter
      G 1 Reply Last reply Reply Quote 0
        goedh452 @peterh
        @peterh
        Hi Peter,
        Great it is working out for you! In the config there is a question that the lower part breaks when it encounters a temperature. Is that right? It should be able to show temperatures as well.
          peterh @goedh452
          @goedh452
          Hi
          rooms: [
          I have a “room” plan set in Domoticz that contains various virtual devices, if i add a temperature device to it, the list of devices shown in MM stops at that device.
          With “mote” (temp & humidity) sensor in the room
          With no mote in the room.
          Please note: I have used custom css to shrink the members of the room to a more compact left justified list, rather than spread across the whole width of the screen.
          regards Peter
          G 2 Replies Last reply Reply Quote 0
            goedh452 @peterh
            @peterh
            I can have a look at the temp/hum issue. I have several of these sensors myself and they do work in this layout. I would need the JSON-output of the specified device to figure out the problem.
              goedh452 @peterh
              @peterh
              I tried, but am unable to reproduce your problem. If you would like me to have a look, please post the JSON result for the device “mote”.
                peterh @goedh452
                @goedh452
                Hi
                Sorry for the delayed response.
                It appears that the issue occurs when there is no temperature or humidity data in the json output.
                the sensor had no data while i was initially testing. After collecting some data it works as expected.
                sample json data:
                pi@MM-lite:~$ curl "http://10.60.2.252:8080/json.htm?type=devices&rid=196"
                        "ActTime" : 1623221642,
                        "AstrTwilightEnd" : "18:46",
                        "AstrTwilightStart" : "05:45",
                        "CivTwilightEnd" : "17:46",
                        "CivTwilightStart" : "06:45",
                        "DayLength" : "10:07",
                        "NautTwilightEnd" : "18:16",
                        "NautTwilightStart" : "06:15",
                        "ServerTime" : "2021-06-09 14:54:02",
                        "SunAtSouth" : "12:16",
                        "Sunrise" : "07:12",
                        "Sunset" : "17:19",
                        "app_version" : "2020.2 (build 12917)",
                        "result" :
                                        "AddjMulti" : 1.0,
                                        "AddjMulti2" : 1.0,
                                        "AddjValue" : 0.0,
                                        "AddjValue2" : 0.0,
                                        "BatteryLevel" : 255,
                                        "CustomImage" : 0,
                                        "Data" : "0, 27.0",
                                        "Description" : "temperature and humidity in my office. polled from mqtt",
                                        "Favorite" : 0,
                                        "HardwareDisabled" : false,
                                        "HardwareID" : 3,
                                        "HardwareName" : "virtual hardware",
                                        "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
                                        "HardwareTypeVal" : 15,
                                        "ID" : "14114",
                                        "LastUpdate" : "2021-01-04 17:58:14",
                                        "Name" : "mote",
                                        "Notifications" : "false",
                                        "PlanID" : "0",
                                        "PlanIDs" :
                                                0
                                        "Protected" : false,
                                        "ShowNotifications" : true,
                                        "SignalLevel" : "-",
                                        "SubType" : "THGN122/123/132, THGR122/228/238/268",
                                        "Timers" : "false",
                                        "Type" : "Temp + Humidity",
                                        "TypeImg" : "temperature",
                                        "Unit" : 1,
                                        "Used" : 1,
                                        "XOffset" : "0",
                                        "YOffset" : "0",
                                        "idx" : "196"
                        "status" : "OK",
                        "title" : "Devices"
                With Temperature and humidity
                        "ActTime" : 1623222662,
                        "ServerTime" : "2021-06-09 15:11:02",
                        "Sunset" : "17:19",
                        "result" :
                                        "AddjMulti" : 1.0,
                                        "AddjMulti2" : 1.0,
                                        "AddjValue" : 0.0,
                                        "AddjValue2" : 0.0,
                                        "BatteryLevel" : 14,
                                        "CustomImage" : 0,
                                        "Data" : "32.2 C, 34 %",
                                        "DewPoint" : "14.35",
                                        "Favorite" : 0,
                                        "HardwareID" : 3,
                                        "HaveTimeout" : false,
                                        "Humidity" : 34,
                                        "HumidityStatus" : "Comfortable",
                                        "ID" : "14114",
                                        "LastUpdate" : "2021-06-09 15:10:35",
                                        "Name" : "mote",
                                        "PlanID" : "0",
                                        "PlanIDs" :
                                                0
                                        "Temp" : 32.19,
                                        "Timers" : "false",
                                        "Unit" : 1,
                                        "Used" : 1,
                                        "XOffset" : "0",
                                        "YOffset" : "0",
                                        "idx" : "196",
                                        "trend" : 1
                        "status" : "OK",
                        "title" : "Devices"
                mote sensor appears now, above the snake enclosure light.
                thanks again for your attention
                  maxs
                  Hi tanks for great module. I have a small problem with the counter today from the power consumption. this doesn’t show me the amount of use of the day. Gas and water working fine. see screenshot. Do you have a solution, or where I have to search? !!Schermafbeelding 2021-07-24 om 20.59.12.jpg
                    majsoft @Sp0nsje
                      goedh452 @maxs
                      @maxs
                      Alle data is retrieved from the JSON response. Could you post it for the electricity counter?
                        majsoft
                        Hi everyone, please help with setting up customs.css
                        Can anyone advise me how to change the font and icon size only for the first three rooms? (Red marked)
                        I would also need to delete the dividing lines marked in green.
                        I will be very grateful for more detailed advice.
                        customs.css
                        .domoCellState {
                          text-align: right;
                        vertical-align: center;
                          padding-left: 10px;
                        font-size: 300%; 			/* velikost čísla teploměru */
                        color: #FFFFFF;
                        line-height: 100%;
                        .domoIconDiv {
                          padding-right: 5px;
                          font-size: 200%;                        /* velikost ikony teploměru */
                        .domoCell {
                          text-align: left;
                         font-size: 200%;			/* velikost pisma popisku teplomeru - vedle ikony teploměru */
                        line-height: 100%;
                        .domoRoomCell {
                          padding-right: 20px;
                        font-size: 0%;			/* velikost pisma nadpisu room */
                        Config.js
                        the room numbers for which I would like to change the font size are idx 1, 8, 9
                            apiBase: "192.168.2.80",
                            apiPort: "8081",
                                updateInterval: 15,
                        displayType: "room",
                                  alwaysShowDashboard: false,
                                  alwaysShowActions: false,
                                  showButtons: false,
                                         horizontal: true,
                                  columnCount: 3,
                                  dashboardColumnCount: 12,
                                  maxTitleLength: 18,
                             rooms: [
                              { idx: "1" },
                        { idx: "9" },
                        { idx: "8" },
                        { idx: "11" },
                        { idx: "12" },
                        { idx: "13" },
                        Another question is whether it is possible to replace the character C with ° (character Celsius)
                        G M 2 Replies Last reply Reply Quote 0
                        • 12
                        • 13
                        • 7 / 13
