Are you tired of editing config.js, or have trouble doing it, see my new module
@stoffel this is because the scanner failed.
please look at the messages where u start mm
npm start or pm2
if pm2, then the pm2 logs --lines=100
will produce the output. -
thanks sdetweil for your answer,
thats the result:
0|MagicMirror | [24.05.2021 16:24.42.647] [LOG] 0|MagicMirror | stdout: completed 0|MagicMirror | [24.05.2021 16:24.42.672] [ERROR] 0|MagicMirror | stderr 2: /home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595 0|MagicMirror | let tt = data[left]; 0|MagicMirror | ^ 0|MagicMirror | TypeError: Cannot read property '' of undefined 0|MagicMirror | at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595:18) 0|MagicMirror | at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:599:12) 0|MagicMirror | at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:599:12) 0|MagicMirror | at /home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:415:29 0|MagicMirror | at Array.forEach (<anonymous>) 0|MagicMirror | at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:405:24) 0|MagicMirror | at Module._compile (internal/modules/cjs/loader.js:1068:30) 0|MagicMirror | at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10) 0|MagicMirror | at Module.load (internal/modules/cjs/loader.js:933:32) 0|MagicMirror | at Function.Module._load (internal/modules/cjs/loader.js:774:14)
but why or where searched for bootstrap.css.map
i hope you can help me
@stoffel do another git pull… there was a fix yesterday for this… please advise
otherwise send me the config.js and the defaults.js (from the modules folder)
if u edit any personal info (I don’t share), please try to keep all the lines, don’t delete any
send to my email, same userid as here, at gmail.com
i have try it, but all was actuel. also i make an npm install.
not solved the problem. it is an file not found error.
i send you my config.js and the default.js from the moduland thanks for your help
ich muss kurz weg. melde mich später nochmal
@stoffel are you using the MM url
http://mm_address:mm_port/modules/MMM-Config/config.html
got your files… this will take some thinking…
compliments_plus has a data item with lots of .
the forming system can’t handle the dots in the naming scheme
cause it sees the dots as part of the name, not a literal…regular compliments has them as LEADING only, and I can trick it…
compliments plus has trailing and/or embedded…currently there is no escaping mechanism…
I opened issued
https://github.com/sdetweil/MMM-Config/issues/8 -
i’v tryed with my address, the same.
the “…–…–…” are original here
but this], '01-01-....': [ null ], '..-..-....': [ null ]
is the result of MMM-Remote-Control module (edit config), i’v changed it to original
"01-01-....": [ function() {return "<i class=\"fa fa-glass-cheers\"></i> Happy New Year! " + moment().format("YYYY")} ], "..-..-....": [ function() {return moment().locale(config.language).format("dddd, D MMMM")} // https://forum.magicmirror.builders/topic/13332/reloading-config-defaults-or-module ],
the same problem
i have searched here for the missing file, nothing.i am testing again ;-)
@stoffel the missing file is not involved…
if the name contains a ‘.’ , it breaks the system. the only example I had was compliments, which had leading dots…
Wow!
Great module! I just checked out compatibility with my modules and am very impressed.
I’ll leave you some feedback on GitHub. -
ok, but it works with this 2 variante.
what system breaks ? mm or MMM-Config ?
i’v comment out the compliments_plus modul in the config.js but is the same result
