    Need help MMM-touch MMM-pages MMM-page indicator
    27 Posts 7 Posters 4.7k Views 9 Watching
      CurlyQ12391 @MMRIZE
      @MMRIZE, thank you for catching those gesture name errors and giving my another example. I FINALLY GOT IT :)
      			module: "MMM-Touch",
      			position: "bottom_bar",
      			    disabled: false,
      				debug: false,
      				useDisplay: false,
      				autoMode: false,
      				defaultMode: "default",
      					gestureCommands: {
      					  "default":{
      							"TAP_1": (commander) => {commander.sendNotification("USER_PRESENCE", true);},
      							"SWIPE_LEFT_1": (commander) => {commander.sendNotification("PAGE_DECREMENT", null);},
      							"SWIPE_RIGHT_1": (commander) => {commander.sendNotification("PAGE_INCREMENT", null);},
      I tried to change things systematically to determine what truly made it start working was the addition of payload after “USER_PRESENCE” and oddly enough adding semicolons at the end of each gesture command.
      Hopefully this thread can help someone else down the line :)
      T 1 Reply Last reply Reply Quote 1
      • T Offline
        tburk32 @CurlyQ12391
        @CurlyQ12391 @MMRIZE, I followed this thread to enable the swipe left and right to change pages but I’ve run into an issue that this only works when I have the dev console open, either using npm start dev or npm run start followed by ctrl+shift+i. Do you have any ideas why it would only work when the dev console is open?
          sdetweil @tburk32
          @tburk32 no. the code doesn’t know
          T 1 Reply Last reply Reply Quote 0
            sdetweil @tburk32
            @tburk32 also, before 2.30
            you could do
            npm start dev
            on 2.30, because of the different ui engine choices
            npm run start:dev
            • T Offline
              tburk32 @sdetweil
              @sdetweil I agree, but it isn’t the way it’s acting. When I have it in the dev console, a grey circle also appears on the screen as a cursor and I’m wondering if that is part of the difference.
                sdetweil @tburk32
                @tburk32 maybe the dev console gives you access under the z-index for touch
                • T Offline
                  tburk32 @sdetweil
                  @sdetweil I removed all of the other modules in my config.js file and experienced the same results. To go one step further with the z-index exploration, I added this to the custom.css.
                  .MMM-Touch (position: absolute; z-index -1)
                  Additionally, while having the dev console open, clicks with a mouse also register on MMM-Touch, so I it doesn’t seem like it’s unique to the display/touch function.
                  I really appreciate your responses so far.
                    sdetweil @tburk32
                    @tburk32 you have an error there
                    css has
                    your z-index is missing both : and ;
                    and -1 means background, down/further away , in the 3d stack
                    so that puts other content on top of it, so touch wont work
                    • T Offline
                      tburk32 @sdetweil
                      @sdetweil thanks for pointing out the -1 index, I saw it as a resolution on another topic and figured I’d try. No values in the z-index seem to make a difference.
                      While in devtools, I selected “restore defaults and reload” and the MMM-Touch inputs were no longer recognized, which aligns with the expectation that “the code doesn’t know”. This helped me realize that the Device toolbar (ctrl+shift+M) has to be displayed for the inputs to be recognized again, either with a touch or a click.
                        sdetweil @tburk32
                        @tburk32 did you enable touch events in custom.css
                        cause they are disabled by default in main.css
                        main.css
                        html {
                          cursor: none;
                        custom.css
                        html {
                          cursor: default;
                        • 2 / 3
