    Calendar randomly stops updating itself
    8 Posts 4 Posters 1.1k Views 4 Watching
    • O Offline
      outlying
      Hi, I will start with I’m on 2.20.0 version of MM but this issue is bothering me for a long time so, the problem is … calendar randomly stops updating itself, I see mirror, and every other module is updated (date/time, weather, news, etc) but, for example, right now calendar is showing me, on its first position, event which ended yesterday (almost 24h ago).
      Sometimes I realize that the calendar is not working because the calendar event I added is not appearing on the mirror display.
      Configuration is not very complicated and it is working (if I restart MM), for obvious reason those are not full Google calendar URLs
                              module: "calendar",
                              header: "Kalendarz",
                              position: "top_left",
                                      maximumNumberOfDays: 31,
                                      showLocation: true,
                                      wrapEvents: true,
                                      timeFormat: "absolute",
                                      fetchInterval: 120000,
                                      calendars: [
                                                      symbol: "calendar-check",
                                                      url: "https://calendar.google.com/calendar/ical/"
                                                      symbol: "calendar-alt",
                                                      url: "https://www.thunderbird.net/media/caldata/PolishHolidays.ics"
                                                      symbol: "rocket",
      Usually, I restart MM but thing keeps bothering me
      FoziF S 2 Replies Last reply Reply Quote 0
      • FoziF Offline
        Fozi Project Sponsor @outlying
        @outlying Just for assurance:
        The calendar URLs you’re posting are the real ones or just abbreviated for privacy here?
        HowTo: Replace PIR Sensor with a RCWL-0516 Microwave Sensor
          sdetweil @Fozi
          @Fozi he said they were not actual.
          FoziF 1 Reply Last reply Reply Quote 0
            sdetweil @outlying
            @outlying can u tell us about your environment?
            I think if there is a fetch error, it’s not recoverable…
            u might be able to see this in the startup console if u change the config.js logLevel like this
            logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
            and start mm with
            npm start > somefile.txt
            (so u need to stop mm if using pm2 )
            • FoziF Offline
              Fozi Project Sponsor @sdetweil
              @sdetweil Yeah, I see… When I setup calendar quite some time ago I remember that I had some trouble, too.
              What I did -I cant’t remember why because it is undocumented- was to change
              from
              to
              timeFormat: "HH:mm",
              That is a shot in the dark, but might help, too.
              O 1 Reply Last reply Reply Quote 0
              • O Offline
                outlying @Fozi
                Sure I will respond with the results in a couple of days but I moved to another apartment and my mirror is not yet running (I hoped it will not take that long).
                But the problem with logs is, that it might take a couple of days, usually, after the restart, it works fine for a week or two, maybe more, and suddenly stops.
                  sdetweil @outlying
                  @outlying ok, that sounds like a networking problem, causing an error and never recovering
                    DezHak
                    I have noticed the same thing, or rather my Ma has on the one I made for her. Some times the news won’t update until it power cycles again. If nothing bad happens to the breaker sometimes will display same news from a month ago.
