    Electron v20 will coming with next release but...
    Scheduled Pinned Locked Moved Upcoming Features
    9 Posts 5 Posters 4.8k Views 5 Watching
      sdetweil @karsten13
      @karsten13 @bugsounet
      I opened this MM issue
      https://github.com/MichMich/MagicMirror/issues/2903
        sdetweil @sdetweil
        at least in the case of PIR, it appears
        MMM-PIR-Sensor-Lite works as it uses python for triggering
        https://github.com/grenagit/MMM-PIR-Sensor-Lite
        • kayakbabeK Offline
          kayakbabe
          I saw on those github issues posed above that
          “This will result in applications that use epoll/onoff being broken after Electron 12.”
          That means most of the button and input sensor type magicmirror modules will probably break.
          So, I"m kinda glad I broke my new button module. and found this info right after. I think I"m going to go with a python based script and bypass the node on/off and epoll. So back to the drawing board.
            sdetweil @kayakbabe
            @kayakbabe where do you see 12?
            all is ok to 19
            kayakbabeK 1 Reply Last reply Reply Quote 0
              kayakbabe @sdetweil
              @sdetweil said in Electron v20 will coming with next release but...:
              all is ok to 19
              https://github.com/fivdi/epoll/issues/42
              Top comment by David
