MMM-NewsFeed multiple instances
Hello everybody,
I am trying to duplicate the MMM-NewsFeed module because I would like to call it twice from the MMM-Pages module.
The guides on the forum have had no effect, the module is not loaded.Can you help me?
Thanks as always.
@Egnos this module does not support multiple instances
you can try to use the copy approach
copy the MMM-Newsfeed module folder
to another named folder in the module directory, MMM-Newsfeed2 for examplein the new folder, rename the MMM-Newsfeed.js to match the new folder name. MMM-Newsfeed2.js
edit that file and change the module.register(
to use the new folder namein all cases the new name must match exactly as the system is case sensitive.
then in config.js use the new folder name for module:
I have already tried your advice but it didn’t work.
The strange thing is that if I launch the two modules together, only MMM-NewsFeed starts.
If I start them individually then the MMM-NewsFeed2 works too.
When launched together, MMM-NewsFeed always prevails, not allowing the execution of MMM-NewsFeed2.daniele@raspberry:~/MagicMirror $ npm start > [email protected] start > ./run-start.sh $1 [15.09.2022 13:57.13.128] [LOG] Starting MagicMirror: v2.20.0 [15.09.2022 13:57.13.132] [LOG] Loading config ... [15.09.2022 13:57.13.135] [LOG] Loading module helpers ... [15.09.2022 13:57.13.137] [LOG] No helper found for module: alert. [15.09.2022 13:57.13.148] [LOG] Initializing new module helper ... [15.09.2022 13:57.13.148] [LOG] Module helper loaded: updatenotification [15.09.2022 13:57.13.149] [LOG] No helper found for module: clock. [15.09.2022 13:57.13.379] [LOG] Initializing new module helper ... [15.09.2022 13:57.13.379] [LOG] Module helper loaded: MMM-SystemStats [15.09.2022 13:57.13.427] [LOG] Initializing new module helper ... [15.09.2022 13:57.13.427] [LOG] Module helper loaded: MMM-NewsFeed [15.09.2022 13:57.13.437] [LOG] Initializing new module helper ... [15.09.2022 13:57.13.437] [LOG] Module helper loaded: MMM-NewsFeed2 [15.09.2022 13:57.13.438] [LOG] All module helpers loaded. [15.09.2022 13:57.13.491] [LOG] Starting server on port 8080 ... [15.09.2022 13:57.13.501] [LOG] Server started ... [15.09.2022 13:57.13.502] [LOG] Connecting socket for: updatenotification [15.09.2022 13:57.13.502] [LOG] Starting module helper: updatenotification [15.09.2022 13:57.13.503] [LOG] Connecting socket for: MMM-SystemStats [15.09.2022 13:57.13.503] [LOG] Connecting socket for: MMM-NewsFeed [15.09.2022 13:57.13.504] [LOG] [FEED] MMM-NewsFeed Version: 1.2.0 [15.09.2022 13:57.13.505] [LOG] Connecting socket for: MMM-NewsFeed2 [15.09.2022 13:57.13.506] [LOG] [FEED] MMM-NewsFeed Version: 1.2.0 [15.09.2022 13:57.13.507] [LOG] Sockets connected & modules started ... [15.09.2022 13:57.13.507] [LOG] Ready to go! Please point your browser to: http://localhost:8080 Starting chromium browser now, have patience, it takes a minute [15.09.2022 13:57.16.780] [INFO] Checking git for module: MMM-SystemStats [15.09.2022 13:57.16.835] [INFO] Checking git for module: MMM-NewsFeed [15.09.2022 13:57.16.850] [INFO] Checking git for module: MMM-NewsFeed2 [15.09.2022 13:57.16.865] [INFO] Checking git for module: default [15.09.2022 13:57.23.546] [LOG] [FEED] MMM-NewsFeed est now initialized! [15.09.2022 13:57.23.910] [LOG] [FEED] MMM-NewsFeed est now initialized!
I realized that the two instances overlap, regardless of the position given in the configuration.
both modules work (MMM-NewsFeed and MMM-NewsFeed2) but “cover” each other … -
@Egnos then you would have to have to fiddle with CSS
so would have to rename the css file and change the response to getStyles to the new name…THEN you could use custom.css to attempt to fix
as I said, you could ‘try’ the rename approach… sometimes not so easy…
@sdetweil said in MMM-NewsFeed multiple instances:
Below the “MMM-NewsFeed2.css” file contained in the module but I can’t find "getStyles ":
/* Magic Mirror * Module: NewsFeed * * By @bugsounet -- Dupont Cédric <[email protected]> * MIT Licensed. */ #NEWSFEED_CONTENER { line-height:1.1em; width: 100%; } #NEWSFEED_CONTENER.showArticle { opacity: 1; transition: opacity 1s linear; } #NEWSFEED_CONTENER.hideArticle { opacity: 0; transition: opacity 1s linear; } #NEWSFEED_TITLE { margin-left: auto; margin-right: auto; white-space: nowrap; overflow: hidden; text-overflow: ellipsis; } #NEWSFEED_ARTICLE { font-size: 90%; display: flex; } #NEWSFEED_CONTENT { padding: 10px; margin-top: 1px; font-size: 70%; text-align: left; height: 80px; display: flex; } #NEWSFEED_IMAGE { margin-right: 10px; float: left; max-width: 10vw; max-height: 10vh; text-align: left; } #NEWSFEED_DESCRIPTION { opacity: 0; line-height: 25px; text-align: justify; overflow: hidden; text-overflow: ellipsis; display: -webkit-box; -webkit-line-clamp: 3; -webkit-box-orient: vertical; } #NEWSFEED_DESCRIPTION.showArticle { animation: 3s ease 0s normal forwards 1 fadein; } @keyframes fadein{ 0% { opacity:0; } 66% { opacity:0; } 100% { opacity:1; } } #NEWSFEED_DESCRIPTION.hideArticle { opacity: 1; animation: none; } #NEWSFEED_FOOTER { text-align:right; } #NEWSFEED_LOGO { font-size: 100%; font-weight: bold; display: flex; } #NEWSFEED_LOGO_PARTA { margin-left: 10px; } #NEWSFEED_LOGO_PARTB { margin-right: 10px; } #NEWSFEED_SOURCE { margin-right: 8px; font-weight: bold; margin-top: -9px; margin-bottom: 5px; text-align: left; } #NEWSFEED_SOURCE.start { animation-duration: .8s; animation-name: clignoter; animation-iteration-count: 2; transition: none; animation-delay: 1s; } #NEWSFEED_SOURCE.stop { animation-name: stopclignoter; animation-iteration-count: 1; } @keyframes clignoter { 0% { opacity:1; } 40% { opacity:0; } 100% { opacity:1; } } @keyframes stopclignoter { 0% { opacity:1; } } #NEWSFEED_TIME { font-size: 50%; text-align: right; display: inline-block; margin-right: 10px; margin-top: 10px; margin-bottom: -5px; } #NEWSFEED_INFO { width: 100%; height: 110px; } #NEWSFEED_QRCODE { height: 120px; width: 120px; margin-top: 0px; margin-right: -10px; margin-left: 5px; } /** Vertical **/ #NEWSFEED_TITLE.vertical { display: none; } #NEWSFEED_CONTENT.vertical { font-size: 80%; display: inline-block; } #NEWSFEED_IMAGE.vertical { float: unset; display: block; margin-left: auto; margin-right: auto; /* max-width: 20vw; max-height: 20vh; */ } #NEWSFEED_SOURCE.vertical { text-align: center; margin-top: auto; margin-bottom: auto; line-height: 22px; } #NEWSFEED_QRCODE.vertical { height: 100px; width: 100px; min-width: 100px; min-height: 100px; /* display: inline-block; */ margin-right: 0px; margin-top: 3px; margin-left: 0px; } #NEWSFEED_CONTENER_TITLE { display: flex; } #NEWSFEED_DESCRIPTION.vertical { line-height: 20px; margin-top: 5px; -webkit-line-clamp: 10; } #NEWSFEED_TIME.vertical { font-size: 60%; margin-top: 0px; }
@Egnos Why don’t you try different modules?
@Anthony said in MMM-NewsFeed multiple instances:
Hi @Anthony, I have not found any RSS Feed modules that show the image of the article.
Do you have something to advise me?Thanks.
@Egnos getStyles is in the MMM-Newfeed2.js
