    Default weather font size
    6 Posts 3 Posters 1.3k Views 3 Watching
    • K Offline
      KD
      Hello All, i am trying to change the default weather and the header of the forcast font size but am really struggling… can someone please help?
      Basically everything highlighted in yellow
      • BKeyportB Offline
        BKeyport Module Developer @KD
        @KD This is going to slightly change (I reworked some of the sizing CSS that’s been accepted into the develop branch) however, here’s what I recommend you do.
        My instructions are based on Windows Edge. Adjust as needed.
        Access the mirror webpage from another computer. You may have to change the “address” line in config.js to “0:0:0:0” from “localhost”… the default address will be http://{PiHostName}.local:8080 or http://X.X.X.X:8080 (by IP address) This shows your mirror on a computer you have more control over.
        Use the developer tools (F12) to access the gritty behind the webpage. In that window there will be a icon that is a pointer at a screen in the upper left corner. If you click that, you can use your mouse to highlight the css elements you need. More than likely they would show something along the lines of class="module-header" and the like. You can use this in your own custom.css to alter it. More than likely, based on the CSS file in the directory, the classes it’s using is coming from main.css - you can copy and paste the classes to custom.css fix it your way. DO NOT CHANGE MAIN.CSS
          sdetweil @BKeyport
          @BKeyport
          .modulename  .module-header {
                font-size:
          • BKeyportB Offline
            BKeyport Module Developer @sdetweil
            @sdetweil … or you could just have someone give you the answer, rather than figuring it out yourself. 🤣
              sdetweil @BKeyport
              @BKeyport well, my text doesn’t work as is…
              I try to point them to the dev window instructions
              https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1663441193880
                sdetweil @BKeyport
