    JSON request module
    Scheduled Pinned Locked Moved Solved Requests
    41 Posts 3 Posters 11.1k Views 4 Watching
      ELMAGO @wishmaster270
      @wishmaster270
      good evening,
      I tested the replace function:
      		module: "MMM-ValuesByNotification",
      		position: "top_right",
      		header: "INFORMATION MÉGANE",
      			updateInterval: 300,
      			reuseCount: 100,
      			addClassesRecursive: true,
      			valueFormat: "\"${value}\".replace(\"false\",\"Non\").replace(\"true\",\"Oui\")",
      			groups: [
      					items: [
      							notification: "AUTBATTMEGANE",
      							itemTitle: "Autonomie  ",
      							values: [
      									valueUnit: " Km",
      									valueFormat: "Number(${value}).toFixed(2)",
      									jsonpath: "data",
      							notification: "BATTMEGANE",
      							itemTitle: "Charge batterie  ",
      							values: [
      									valueUnit: " %",
      									jsonpath: "data",
      							notification: "PLUGMEGANE",
      							itemTitle: "Voirture branchée ",
      							classes: "withIcons",
      							values: [
      									jsonpath: "data",
      But unfortunately it doesn’t work.
      Would you know why?
      wishmaster270W 1 Reply Last reply Reply Quote 0
      • wishmaster270W Offline
        wishmaster270 Module Developer @ELMAGO
        @ELMAGO As valueFormat settings further down in the hierarchy override setting further up you only have to much valueFormat settings.
        This config should do the trick:
        			reuseCount: 100,
        			groups: [
        					items: [
        							values: [
        									valueUnit: " Km",
        									jsonpath: "data",
        							values: [
        									valueUnit: " %",
        									jsonpath: "data",
        							values: [
        									jsonpath: "data",
          ELMAGO
          Hi @wishmaster270
          I come back here, it will be simpler.
          My code is:
          //INFORMATION HOMEY EUFY
             module: "MMM-CommandToNotification",
             disabled: false,
              commands: [
                     script: "/usr/bin/curl",
                     args: "-s  http://192.168.100.244:3000/ETATEUFY",
                     timeout: 1000,
                     notifications: [
                      "ETATEUFY",
                     args: "-s  http://192.168.100.244:3000/CAMSALLE",
                     timeout: 1000,
                     notifications: [
                      "CAMSALLE",
                     args: "-s  http://192.168.100.244:3000/CAMPALIER",
                     timeout: 1000,
                     notifications: [
                      "CAMPALIER",
                     args: "-s  http://192.168.100.244:3000/CAMARRIERE",
                     timeout: 1000,
                     notifications: [
                      "CAMARRIERE",
                     args: "-s  http://192.168.100.244:3000/CAMGARAGE",
                     timeout: 1000,
                     notifications: [
                      "CAMGARAGE",
                     args: "-s  http://192.168.100.244:3000/CAMGAUCHE",
                     timeout: 1000,
                     notifications: [
                      "CAMGAUCHE",
                     args: "-s  http://192.168.100.244:3000/CAMAVANT",
                     timeout: 1000,
                     notifications: [
                      "CAMAVANT",
                args: "-s  http://192.168.100.244:3000/TEMPSALLE",
                timeout: 1000,
                notifications: [
                 "TEMPSALLE",
                     args: "-s  http://192.168.100.244:3000/TEMPBUREAU",
                     timeout: 1000,
                     notifications: [
                      "TEMPBUREAU",
                     args: "-s  http://192.168.100.244:3000/TEMPCHELENA",
                     timeout: 1000,
                     notifications: [
                      "TEMPCHELENA",
                     args: "-s  http://192.168.100.244:3000/TEMPCHLOUCA",
                     timeout: 1000,
                     notifications: [
                      "TEMPCHLOUCA",
                     args: "-s  http://192.168.100.244:3000/TEMPCHALAN",
                     timeout: 1000,
                     notifications: [
                      "TEMPCHALAN",
                     args: "-s  http://192.168.100.244:3000/TEMPCHPARENT",
                     timeout: 1000,
                     notifications: [
                      "TEMPCHPARENT",
                	args: "-s  http://192.168.100.244:3000/AUTBATTMEGANE",
                	timeout: 1000,
                	notifications: [
                 	"AUTBATTMEGANE",
                     args: "-s  http://192.168.100.244:3000/BATTMEGANE",
                     timeout: 1000,
                     notifications: [
                      "BATTMEGANE",
                     args: "-s  http://192.168.100.244:3000/PLUGMEGANE",
                     timeout: 1000,
                     notifications: [
                      "PLUGMEGANE",
                     args: "-s  http://192.168.100.244:3000/CHARGEMEGANE",
                     timeout: 1000,
                     notifications: [
                      "CHARGEMEGANE",
          So I think it launches all requests at the same time, because my server which must answer crashes.
          I wanted to split it like this:
             disabled: false,
              commands: [
                     timeout: 1000,
                     notifications: [
                      "ETATEUFY",
                     timeout: 1000,
                     notifications: [
                      "CAMSALLE",
                     timeout: 1000,
                     notifications: [
                      "CAMPALIER",
                     timeout: 1000,
                     notifications: [
                      "CAMARRIERE",
                     timeout: 1000,
                     notifications: [
                      "CAMGARAGE",
                     timeout: 1000,
                     notifications: [
                      "CAMGAUCHE",
                     timeout: 1000,
                     notifications: [
                      "CAMAVANT",
          and
             disabled: false,
              commands: [
                timeout: 1000,
                notifications: [
                 "TEMPSALLE",
                     timeout: 1000,
                     notifications: [
                      "TEMPBUREAU",
                     timeout: 1000,
                     notifications: [
                      "TEMPCHELENA",
                     timeout: 1000,
                     notifications: [
                      "TEMPCHLOUCA",
                     timeout: 1000,
                     notifications: [
                      "TEMPCHALAN",
                     timeout: 1000,
                     notifications: [
                      "TEMPCHPARENT",
          and :
             disabled: false,
              commands: [
                	timeout: 1000,
                	notifications: [
                 	"AUTBATTMEGANE",
                     timeout: 1000,
                     notifications: [
                      "BATTMEGANE",
                     timeout: 1000,
                     notifications: [
                      "PLUGMEGANE",
                     timeout: 1000,
                     notifications: [
                      "CHARGEMEGANE",
          But it doesn’t work, only the last element appears.
            @ELMAGO Hi,
            thats right. The module does not support multi instance configurations.
            You will need to copy the complete module folder and change some things to get it work.
            But to me it looks like your server is stressed with the 16 calls straight after each other. So you do not need more parallelism but less.
            So i will check if i can at a configurable delay after each command to stretch the time the calls get made to your server a little bit.
            E S 2 Replies Last reply Reply Quote 0
              @wishmaster270
              good morning
              I don’t mind doing it by hand if you explain to me what I need to change
                @ELMAGO Hi,
                i just released a new version of the module which has a new option delayNext that can be added to each command.
                The module then starts the command and waits this amount of milliseconds before the next one is processed.
                So in your case you can add a delayNext: 1000 to each of the commands to give your server some time between the calls.
                  sdetweil @wishmaster270
                  @wishmaster270 you could make it support multi instance easily
                  in the modulename.js when u sendSocketNotification… add the module id to the data
                  in the node_helper, send the id back
                  in the modulename.js in receiveSocketNotification
                  check that the returned id matches this instances id
                  sendSocketNotification from the node_helper is a broadcast , all instances get it at the same time, thus the need for the check.
                    wishmaster270 Module Developer @sdetweil
                    @sdetweil Hi Sam, I will check that for the next release.
                    I already added something similar to one of my other modules but did not know that there is a module id already and added a uuid instead.
                      @wishmaster270 this.indentifier
                      https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties
                        @wishmaster270
                        ok, i test
                        • BKeyportB BKeyport referenced this topic on
                        • 4 / 5
