    monitor power button unreachable
    9 Posts 4 Posters 938 Views 4 Watching
      SILLEN 0
      hey im looking for advice on how to fix a problem with my magicmirror monitor. so i have built a magicmirror as a christmas present and everything software side works but when i plug everything together the display doesnt automatically turn on, i have to press the monitors power button. but the problem is that the powerbutton is on the other side against the glass already stuck on and i cant rebuild it in time. i checked if i could use cec client to turn it on but my monitor doesnt support that. any other suggestions? thanks
      S D J 4 Replies Last reply Reply Quote 1
        sdetweil @SILLEN 0
        @SILLEN-0 sadly I don’t think there is any easy solution.
          DarrenHill @SILLEN 0
          @SILLEN-0 Would you be able to dismantle it (carefully) enough to get rear access to the button?
          I was thinking either to be able to remove and relocate it perhaps, or to solder a switch or other solution in parallel to the existing one to put that somewhere accessible?
            jturczak @SILLEN 0
            @SILLEN-0 you might try looking in the monitor setup for a power option that turns on the monitor when power is applied.
              jturczak
              @SILLEN-0 look in the monitor set up itself.
                jturczak @SILLEN 0
                @SILLEN-0 Doesn’t your MM run off a Raspberry Pi? When it powers up you should get a signal to power the monitor from the HDMI cable… check your pi settings also for autoboot
                S S 2 Replies Last reply Reply Quote 0
                  sdetweil @jturczak
                  @jturczak just fyi. every post from users with less than 2 reputation are reviewed before being posted on the forum. this stops all the spam we get.
                    SILLEN 0 @jturczak
                    @jturczak hey sorry for late reply thing were alittle bit stressful before christmas turn out i was just stupid and there was just an error in the config when the mirror didnt connect to the home network and because of that i just got a blank mirror i didnt notice that it was on but just not displaying anything. thank you so much for your help
                    J 1 Reply Last reply Reply Quote 2
                      jturczak @SILLEN 0
                      @SILLEN-0 lol yeah that config file can be touchy. I’m glad you figured it out. Happy new year!
