    MMM-NOAAAlerts
    3 Posts 3 Posters 707 Views 3 Watching
    • mattkabM Offline
      mattkab
      I built this module more by need than anything else – the Seattle area where I live has been hit by some relatively severe weather the past few days, that have caused real problems for the area. While I wasn’t caught off-guard this time, I realized that the MM weather modules I had didn’t emphasize local warnings, alerts, and weather watches. So I built a module expressly for solving that problem:
      MMM-NOAAAlerts
      Special Weather Statement:
      Flood Warning:
      USING THE MODULE
      Github Link
      Standard installation:
      git clone https://github.com/mmtsweng/MMM-NOAAAlerts
      cd MMM-NOAAAlerts
      npm install
      Basic configuration:
        module: "MMM-NOAAAlerts",
        position: "top_bar",
            userAgent: "Magic Mirror ([email protected])" //Custom contact information
            APIURL: "https://api.weather.gov/alerts/active?point=47.593,-122.333", //See below for other options
            debug: false, // [Optional] Print extended debugging logs to the console
            rotateInterval: 20*1000, // [Optional] How often to switch to the next alert/alarm
            updateInterval: 30*60*1000, // [Optional] How often to ping the API for more data
      NOAA provides a free API to retrieve weather alerts, which this API uses. There is no registration required.
      There are multiple ways to set the forecast area, and NOAA provides through documentation if you need extensive help. But the basics are
      • By State: https://api.weather.gov/alerts/active?area={state}
      • By Zone: https://api.weather.gov/alerts/active?zone={zone}
      • By Lat/Long: https://api.weather.gov/points/{latitude},{longitude}
      • By Grid: https://api.weather.gov/gridpoints/{office}/{grid X},{grid Y}/forecast
      NOAA requires that a User-Agent header be provided. Please set your own custom agent in the config with unique contact information (the suggested header is: User-Agent: (myweatherapp.com, [email protected]) , so following that format makes sense.
      This is still very much a work in progress. I have spent very little time styling it, and I haven’t even put together the README file yet (I’m going to steal this post, actually!). But I have had it running for the past 2 days with no major issues. So far I’ve only tested it in the top bar section. If anyone else wants to try it and provide feedback I’ll be actively improving it.
      KristjanESPERANTOK 1 Reply Last reply Reply Quote 2
        mmmallday
        Working for me. Thanks!
        • KristjanESPERANTOK Online
          KristjanESPERANTO Module Developer @mattkab
          @mattkab Please add it to the module list :-)
