    MM stoped working after update MMM-CalDAV
    4 Posts 3 Posters 394 Views 3 Watching
      bdream
      After update of MMM-CalDAV module MM is not more starting
      cheers, bdream
      S M 2 Replies Last reply Reply Quote 0
        sdetweil @bdream
        @bdream show the output of npm start
        pm2 stop all
        cd ~/MagicMirror
        npm start >somefile.txt
        wait 15 seconds
        ctrl-c to stop MM
        then edit somefile.txt
          MMRIZE @bdream
          @bdream
          Give me more details.(Log, what did you do, environment, config, …) And, MMM-CalDAV is rebuilt recently from scratch, so you have to reinstall and many config things are changed.
            bdream @MMRIZE
            @MMRIZE you gave me the hint.
            I have deleted the config-part of MMM-CalDAV and made the update again and it works fine.
            So it seems the config was wrong. Now I have to understand your module and how it works.
            Will play with env and learn about the play with calendar module.
            Lets see if I get it :baby:
            cheers, bdream
