    how alert trigger
    alertsmodulemqtt
    15 Posts 3 Posters 3.1k Views 3 Watching
      sdetweil @fischi87
      @fischi87 yeh it’s a little bit of thinking, as it is two part
      starting here
      1. define the mqtt topic and an arbitrary ‘command’ word to execute when the topic is heard (mqttHook)
      2. define the ‘command’ that has the notification and the payload (mqttNotiCommands)
      and from the alert module doc, start here
      F 2 Replies Last reply Reply Quote 0
        fischi87 @sdetweil
        first of all thank u for ur time.
        i dont understand where i have to write down the sendnotification. i mean i can see in my broker the examples from the mqtt module but how it works now. my understanding is to write something in the config to trigger the alarm.
        for example i use the example from the brige modul how can i use this exemple to trigger a alert? i hope u can understand me.
        thanks
          fischi87 @sdetweil
          i have also a other idea. maybe it is easier to trigger the alert with the MMM-Api module? my broker have also a simple-api adapter.
          but its still my question, how?
            sdetweil @fischi87
            @fischi87 YOU don’t do the sendnotification.
            you take the data from it and configure the module to send it.
            I was just showing you the doc for the alert.module that describes what it wants
            a string for the notification value
            and a object for the notification payload
            these two things go in the command section
            F 1 Reply Last reply Reply Quote 0
              fischi87 @sdetweil
              im so sorry but I don’t understand it. like I wrote I can see the examples in my Mqtt broker.
              when I change in my broker the messages I can also see in the log from the mirror that it changed this values but how can I trigger with this a alert for example or a notification? what I have to configure? in the config.js file by the module: MMM-MQTT-Bridge? when yes what? I copy the examples already.
