    My Magic "Mirror" Desk Display
    Scheduled Pinned Locked Moved Show your Mirror
    18 Posts 6 Posters 11.4k Views 10 Watching
    • BerkSmash1984B Offline
      BerkSmash1984 @Ashaman
      @Ashaman I sent you a DM, but pretty sure I worked @sdetweil on getting it to work via Discord. Definitely try his fork!
        BerkSmash1984 @Egnos
        @Egnos You bet, here you go!
          sdetweil @BerkSmash1984
          @BerkSmash1984 my MMM-Pages fork only updates the doc… didn’t change any code
          BerkSmash1984B 1 Reply Last reply Reply Quote 0
            BerkSmash1984 @sdetweil
            @sdetweil Understood, I know I reached out to you on Discord and you helped me get it setup using classes as an easier way to define the pages in the config, but don’t remember anything beyond that. I did sent @Ashaman a DM though with my config to help him
              Egnos @BerkSmash1984
              @BerkSmash1984
              One question: in “mapUrl” excluding the (x, y) coordinates, how did you compose the url?
              Many thanks!
              My Mirror https://forum.magicmirror.builders/topic/17262/the-raspimirror-was-born/7
                @Egnos I did not, that is from the module itself, but is a configurable item. Take a look at the MMM-ISS-Map-src.js file located in /MagicMirror/modules/MMM-ISS-Map:
                Note that you can change “light_all” and other configurable style options to those supported by CARTO basemaps.
                See:
                https://github.com/CartoDB/basemap-styles
                In my testing with my MagicMirror setup, “light_all” looks best, but def check out the other styles to see what meets your needs!
                  Thanks @BerkSmash1984 for the detailed information!
                  Which version of Raspbian do you run in your RPI?
                    @Egnos Bullseye Release 11
                    • BerkSmash1984B BerkSmash1984 referenced this topic on
