MMM-Fuel
There seems something has changed with the MMM-Fuel that it does not work.
When starting up MagicMirror the MMM-Fuel gives the following error message - as attached below :
[01.04.2024 16:43.25.295] [LOG] [MMM-Fuel]Failed to refresh token FetchError: invalid json response body at https://api.onegov.nsw.gov.au/oauth/client_credential/accesstoken?grant_type=client_credentials reason: Unexpected token ‘<’, "<!DOCTYPE "… is not valid JSON
at /home/pi/MagicMirror/modules/MMM-Fuel/node_modules/node-fetch/lib/index.js:272:32
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async refreshToken (/home/pi/MagicMirror/modules/MMM-Fuel/apis/nsw.js:47:32)
at async module.exports (/home/pi/MagicMirror/modules/MMM-Fuel/apis/nsw.js:218:5)
at async Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Fuel/node_helper.js:25:33) {
type: ‘invalid-json’
}Can some please tell us what is the problem and how it can be fixed.
Thank you and much appreciated.
Regards,
Neel.
