MMM-OpenWeatherForecast Error 401
@Vauxdvihl that command will output which repo the module came from
please show the output
Here ue are
@raspberrypi:~/MagicMirror/modules/MMM-OpenWeatherForecast $ git remote -v origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (fetch) origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast (push)
@Vauxdvihl Okay, so that shows us that you’re using the right fork 👍 Let’s see the part of config.js for this module (without API key, of course).
Thank you
module: "MMM-OpenWeatherForecast", //header: "Wetter Berlin", // Optional header position: "top_right", classes: "default everyone", disabled: false, config: { apikey: "key", latitude: "51.xxxxx", longitude: "-0.xxxxx", iconset: "2c", concise: true, showWind: false, displayKmhForWind: true, animatedIconStartDelay: 2000, label_timeFormat: "HH:mm", forecastLayout: "tiled", forecastHeaderText: "", label_sunriseTimeFormat: "HH:mm", maxHourliesToShow: 0, maxDailiesToShow: 4, label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"], } },
@Vauxdvihl openweathermap discontinued their 2.5 api. so the url in the module might be wrong. Check the configuration possibilities for your module and see if you can choose the 3.0 api.
@kayakbabe
I do not check your answer
While having the default weather module running with “openweathermap” as the source for the datas, everthing runs fine.
And the default module uses according to their css file also the 2.5.I was also switching the “MMM-OpenWeatherForecast” css to 3.0.
Nothing changed
