    Bugsounet and MMM-Pir
    68 Posts 10 Posters 13.8k Views 11 Watching
      myfingersarecold @myfingersarecold
      added to the 3rd party module wiki list under the other PIR modules. github page linked as well.
      https://github.com/ryanjblajda/MMM-SimplePIR
        sdetweil @bitass
        @bitass i didnt say disable the modules. i said disable the notifications
        from the updateNotifications module doc
        https://docs.magicmirror.builders/modules/updatenotification.html#configuration-options
          sdetweil @bitass
          @bitass and he has blocked all his modules
            MMaik100
            so now the EXT-YouTube wont work either?
              sdetweil @MMaik100
              @MMaik100 yes, sadly all his modules will fail eventually, depending on how tight he coupled them
                coernel
                I also just looked for the module as I wanted to contribute some troubleshooting guide and didn’t find it.
                As I have installed the module, what do you think about re-publishing it so that it doesn’t get lost?
                It is MIT-license so no problem about that!
                  coernel
                  I have re-published it already: https://github.com/Coernel82/MMM-Pir
                    sdetweil @coernel
                    @coernel please add it to the third party list
                      lif
                      Is this the correct place to ask questions about the module?
                      If so, is there any way to test that it is actually running?
                      I have installed the module for using a PIR module but nothing appears in the screen in the place I requested it.
                        sdetweil @lif
                        @lif have you verified that the PIR is working outside of MagicMirror??
                        • 2 / 7
