    Bugsounet and MMM-Pir
    68 Posts 10 Posters 13.5k Views 11 Watching
      lif @sdetweil
      @sdetweil said in Bugsounet and MMM-Pir:
      @lif yeh, my upgrade script does the nodejs upgrade too…
      use the n command
      sudo npm install n -g
      sudo n xxx
      where xxx is the version you want to use
      Thanks, added to my install notes
        sdetweil @lif
        @lif n is the nodejs version of nvm
          rkorell @sdetweil
          plan for them all to fail to work
          yes - as stated -really unfortunate!
          Thanks for your clarification!
          Ralf
            lif @sdetweil
            I’ve reinstalled MagicMirror with your script, it worked wonderfully, than you very much for doing this.
            Best regards from France.
              rkorell @rkorell
              @sdetweil @lif
              For your information:
              I was successful with installing MMM-Pir on my brand new Pi5/bookworm:
              pi@MagicMirrorPi5:~ $ cd MagicMirror/modules
              pi@MagicMirrorPi5:~/MagicMirror/modules $ tar -xf MMM-Pir.tar.gz
              pi@MagicMirrorPi5:~/MagicMirror/modules $ cd MMM-Pir/
              pi@MagicMirrorPi5:~/MagicMirror/modules/MMM-Pir $ npm install
              > [email protected] preinstall
              > echo ⚠ npm install will be deprecated on next release!.
              > [email protected] install
              > npm run setup
              > [email protected] presetup
              > npm run dependencies && installer/preinstall.sh
              > [email protected] dependencies
              > installer/dependencies.sh -d 'unclutter ddcutil cec-utils python3 python-is-python3 python3-gpiozero gpiod libgpiod2 libgpiod-dev'
              Welcome to MMM-Pir v2.4.4
              ① ➤ dependencies installer
              Checking OS...
              OS Detected: linux-gnu (debian 12 aarch64)
              Checking all dependencies...
              All Dependencies needed are installed !
              ② ➤ Preinstall
              No root checking...
              Checking MMM-Pir: pi/pi
              Checking MagicMirror: pi/pi
              Installing @sdetweil sandbox fix...
              fixing sandbox permissions
              ③ ➤ Install npm dependencies
              > [email protected] setup
              > npm prune
              up to date in 990ms
              124 packages are looking for funding
                run `npm fund` for details
              > [email protected] postsetup
              > installer/postinstall.sh -m -r
              ④ ➤ Postinstall
              Minify Main code...
              Found: 10 files to install and minify
              Process File: MMM-Pir/MMM-Pir.js
              Process File: MMM-Pir/node_helper.js
              Process File: MMM-Pir/components/cronJob.js
              Process File: MMM-Pir/components/governorLib.js
              Process File: MMM-Pir/components/motion.js
              Process File: MMM-Pir/components/motionLib.js
              Process File: MMM-Pir/components/pirLib.js
              Process File: MMM-Pir/components/screenDisplayer.js
              Process File: MMM-Pir/components/screenLib.js
              Process File: MMM-Pir/components/screenTouch.js
              Done
              Try to Disable screen saver...
              Found: screen saver in gsettings
              disable screensaver via gsettings was true and uint32 300
              Found: screen saver in lightdm
              disable screensaver via lightdm.conf
              Found: screen saver in lxsession
              disable screensaver via lxsession
              Found: wayfire.ini
              [WARN] There is some change for disable screen saver
              [WARN] Please, don't forget to reboot your OS for apply the new configuration!
              Done
              Rebuild MagicMirror...
              ✔ Rebuild Complete
              Done
              MMM-Pir is now installed !
              > [email protected] postinstall
              > echo ⚠ On next release, Please use: npm run setup
              added 1 package in 31s
              I will have to play with the screen options (caused for sure by bookworm) because right now I get an error notification from MMM-Pir (screen error detected: dpms command error(mode 1) ) but there are several other modes to try …
              Regards,
              Ralf
                sdetweil @rkorell
                @rkorell yeh, fun times
                  rkorell @sdetweil
                  @sdetweil yes! :-)
                    FrostByte
                    Hi everyone,
                    I didn’t quite get it right. Are there still problems with MMM-Pir?
                    I see that there are already two pull requests on https://github.com/Coernel82/MMM-Pir/pulls (one is from me). I would be willing to maintain the module, if no one else does.
                    Happy to hear from you @coernel
                      rkorell @FrostByte
                      @FrostByte .
                      Yes there are still “problems”.
                      @coernel has prepared a re-upload of bugsounet’s MMM-Pir.
                      But for some reasons this has failed.
                      Several entities are missing in his upload (including e.g. the core MMM-Pi.js and several other linked and necessary sub-programs (Described in more detail in this post).
                      I’ve copied a tar.gz file of my own local repository-copy here.
                      This copy is installable with npm install in the respective MMM-Pir directory in mirror Version 2.30 (NOT tested in brand new 2.31!).
                      It works without problems on a Pi4 with bullseye.
                      It does NOT work on a Raspi5/bookworm “out of the box”.
                      In the meantime I’ve identified and corrected the root cause for this (wrong parameter for the xrandr-call).
                      This correction is NOT reflected in the URL above because I’ve done this correction after the upload.
                      I can share this with you if you are interested in - only a very minor adoption and only for MY use-case (working without wayland and with x11).
                      From my side it would be really highly appreciated if somebody can take the responsibility for maintenance of this pretty module because I really like it very much.
                      I definitely NOT able to do this but I’m definitely willing to give any additional support in the course of my (tiny) abilities…
                      Let me know what you’re thinking about.
                      Warm regards,
                      Ralf
                      F 1 Reply Last reply Reply Quote 0
                        FrostByte @rkorell
                        Okay, let’s go into detail. @rkorell
                        As already written by @sdetweil , the node_modules directory is created when npm run setup (or npm install as it should be called).
                        In addition, the ‘missing files’ are also created dynamically when this command is called. See:
                        lukas@smartmirror:~/MagicMirror/modules$ git clone https://github.com/Coernel82/MMM-Pir.git MMM-Pir-test
                        lukas@smartmirror:~/MagicMirror/modules$ cd MMM-Pir-test
                        lukas@smartmirror:~/MagicMirror/modules/MMM-Pir-test$ npm run setup
                        lukas@smartmirror:~/MagicMirror/modules/MMM-Pir-test$ ls -al components/
                        total 68
                        drwxr-xr-x  2 lukas lukas  4096 Apr  1 19:06 .
                        drwxr-xr-x 10 lukas lukas  4096 Apr  1 19:53 ..
                        -rw-r--r--  1 lukas lukas  4101 Apr  2 11:23 cronJob.js
                        -rw-r--r--  1 lukas lukas  2241 Apr  2 11:23 governorLib.js
                        -rw-r--r--  1 lukas lukas  3894 Apr  2 11:23 motion.js
                        -rw-r--r--  1 lukas lukas  1563 Apr  2 11:23 motionLib.js
                        -rw-r--r--  1 lukas lukas   757 Mar  3 19:09 MotionSensor.py
                        -rw-r--r--  1 lukas lukas  3755 Apr  2 11:23 pirLib.js
                        -rw-r--r--  1 lukas lukas  6068 Apr  2 11:23 screenDisplayer.js
                        -rw-r--r--  1 lukas lukas 19159 Apr  2 11:23 screenLib.js
                        -rw-r--r--  1 lukas lukas  1763 Apr  2 11:23 screenTouch.js
                        I use Wayland/labwc (Debian GNU/Linux 12 bookworm) on aarch64 Raspberry Pi 3B and everything is working for my Pir configuration. I did not use your copy.
                        So i am asking again, are there some runtime errrors? So please send me errrors logs.
                        The ‘build’ step in package.json is really very confusing. That’s why I’ve started to organise it: https://github.com/Coernel82/MMM-Pir/compare/main...LukasWestholt:MMM-Pir:main#diff-7ae45ad102eab3b6d7e7896acd08c427a9b25b346470d7bc6507b6481575d519
                        Best regards,
                        Lukas
                        • 6 / 7
