    Logging issues
    22 Posts 2 Posters 994 Views 2 Watching
      sdetweil @BKeyport
      @BKeyport browser side goes to the browser console , which you can see in the developers window, console tab (how i debugged your recent problem)
      pm2 only sees the stdout/stderr consoles (so only from node_helpers log. or console.)
      so to merge them together you would use
      MMM-Logging or MMM-LogExt
      then all the messages are logged in the stdout/err console
      i extended logging, MMRIZE did LogExt
      logLevel decides which messages print
      • BKeyportB Online
        BKeyport Module Developer @sdetweil
        Ended up loading it up on my PC to get the console.
        So, here’s what I got…
        1. Apparently, MMM-pages will resume the rotation if you tell it to pause, but it’s already paused.
        2. It should be documented that MMM-pages will pause as part of the hidden pages routine.
        While I was looking and debugging
        Out of curiosity, why would calendar try to update the DOM without being given a location to display
          sdetweil @BKeyport
          @BKeyport module doesn’t know its position (or lack thereof)
          it signals updateDom() which calls getDom()
          oops no place to put it. oh well
          hidden pages stop rotation
          IMG_0832.png .
          i think it says that ‘not in the normal rotation’
          pause while paused restarts is a bug i think, will review
          as i just fixed that area too
            sdetweil @sdetweil
            @BKeyport i looked thru the code and dont SEE a path where pause while paused restarts, but i will test later tonight
            can you show any part of what you logged?
            • BKeyportB Online
              @sdetweil While this is broken up to explain what is sent where, there’s no lines in between other than the diagnostics on the error for “already paused”
              Sent: curl -X GET http://mirrorserv:8080/api/notification/PAGE_CHANGED/0
              [MMM-pages] received a notification to change to page 0 of type string.
              module.js:189 MMM-pages is suspended.
              module.js:189 MMM-CalendarExt3Agenda is suspended.
              module.js:189 MMM-OpenWeatherForecast is suspended.
              module.js:189 MMM-CalendarExt3 is suspended.
              module.js:196 alert is resumed.
              module.js:196 calendar is resumed.
              module.js:196 MMM-Remote-Control is resumed.
              module.js:196 clock is resumed.
              module.js:196 MMM-Worldclock is resumed.
              module.js:196 MMM-Wallpaper is resumed.
              module.js:196 MMM-CalendarExt3 is resumed.
              module.js:196 MMM-CalendarExt3Agenda is resumed.
              module.js:196 MMM-Multimonth is resumed.
              Sent: curl -X GET http://mirrorserv:8080/api/notification/PAUSE_ROTATION/
              MMM-pages.js:311 [MMM-pages] pausing rotation
              Sent: curl -X GET http://mirrorserv:8080/api/notification/PAGE_CHANGED/2
              [MMM-pages] received a notification to change to page 2 of type string.
              3module.js:189 MMM-Multimonth is suspended.
              module.js:196 MMM-OpenWeatherForecast is resumed.
              MMM-pages.js:309 [MMM-pages] was asked to pause but rotation is already paused!
              MMM-pages.js:100 [MMM-pages] received a notification to increment pages!
              etc.
              The diagnostics:
              setRotation	@	MMM-pages.js:309
              notificationReceived	@	MMM-pages.js:123
              sendNotification	@	main.js:99
              sendNotification	@	main.js:649
              sendNotification	@	module.js:350
              socketNotificationReceived	@	MMM-Remote-Control.js:159
              (anonymous)	@	module.js:240
              (anonymous)	@	socketclient.js:32
              Emitter.emit	@	index.js:136
              emitEvent	@	socket.js:553
              onevent	@	socket.js:540
              MMSocket.socket.onevent	@	socketclient.js:26
              onpacket	@	socket.js:508
              (anonymous)	@	manager.js:217
              Promise.then
              (anonymous)	@	globals.js:4
              ondecoded	@	manager.js:216
              add	@	index.js:142
              ondata	@	manager.js:203
              _onPacket	@	socket.js:259
              onPacket	@	transport.js:99
              onData	@	transport.js:91
              ws.onmessage	@	websocket.js:48
                sdetweil @BKeyport
                @BKeyport sent message
                • BKeyportB Online
                  @sdetweil Got message - nothing critical, as usual. and if you have a better way to set page & pause (stop), then later resuming (start) the rotation, I’m all ears.
                  For reference, same configuration as before.
                    sdetweil @BKeyport
                    @BKeyport git pull for update
                    I think you can set page (will resume rotation)
                    then immediately (or before rotationTime) pauseRotation
                    • BKeyportB Online
                      @sdetweil – Pausing is working perfectly, but we moved the bug elsewhere.
                      MMM-pages.js:192 [MMM-pages] cannot change to a named page 0'
                      updatePages	@	MMM-pages.js:192
                      notificationReceived	@	MMM-pages.js:102
                      Promise.then
                      add	@	index.js:142
                        sdetweil @BKeyport
                        @BKeyport can you show me the actual request for page 0
                        its a number, 0 , not a string “0” or ‘0’
                        • 2 / 3
