    How to Use NY Times Subscription with Default Newsfeed Module
    9 Posts 4 Posters 306 Views 4 Watching
      sdetweil @raspberrypi9
      @raspberrypi9 no, no experience w that moduie
        sdetweil @sdetweil
        @raspberrypi9 AND there is no guarantee its the same across providers
          JohnGalt @raspberrypi9
          @raspberrypi9 – Would the content provider happen to have a separate RSS feed for subscribers?
          karsten13K 1 Reply Last reply Reply Quote 0
          • karsten13K Offline
            karsten13 @JohnGalt
            From the sample config the normal feed url is https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml (they maybe have more).
            My first thought was to use https://username:[email protected]/services/xml/rss/nyt/HomePage.xml but the problem here is another one. The feed is free so you need no authentication for the feed but some articles of the feed that should be displayed with ARTICLE_MORE_DETAILS are protected. Because the article urls are extracted from the feed I have no idea how to implement this at the moment.
              JohnGalt @karsten13
              @karsten13 – Yes, that’s what I figured.
              The problem from the provider’s perspective would be how to both give access to legitimate subscribers while limiting access to others. The only solution that springs to mind would be to authenticate the user when they query the server, but for something like this where all the users’ computers might each be coming for content several times each day - it begins to be a lot of computing overhead.
