OpenWeatherForcast - AggregateError?
@cricket no, only for this module…
I can recreate here with my apikey and location and see the working direct url
did take quite a while…we have the fetch timeout set to 30 seconds, so that shouldn’t be it
I am going to reinstall the module as well to see if that works. Update: No change - still loading.{ module: "MMM-OpenWeatherForecast", position: "top_right", header: "Forecast", config: { apikey: "mykey", //only string here latitude: 43.030099, //number works here longitude: -89.449056 //so does a string } },
@cricket the ‘Loading’ error means the front end (displaying data) is waiting for the data to arrive from the backend (node_helper.js)
almost NO module reports and handles critical failures like this.
so we asked for data, and nothing… still wating…I upgraded nodejs, electron and still fails in same place.
I follow some of what you have said. Thanks for your help. Hopefully it is something that can be corrected.
@sdetweil said in OpenWeatherForcast - AggregateError?:
Does this mean you are having the same issue I am?
@cricket yes, I said I could recreate your problem.
https://forum.magicmirror.builders/post/126268 -
@sdetweil Not sure what happened, but it just started working for me… Now on to some configuration. Many thanks for all your help.
@cricket awesome!!
