[ERROR] _ is not defined
@nowayto weird, and npm start fails again _ not defined?
i installed solarpicture without problems
I’m sure.I don’t think SolarPicture could be the problem.Yes, the error keep showing
@nowayto wild, lets do this… intall MM again, but save the current…
#backup MM config and modules list bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" #rename the MagicMirror folder out of the way cd ~ mv MagicMirror MagicMirror.save #and install MM again bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)" #restore the MM config and modules bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_restore.sh)"
then
cd ~/MagicMirror npm start
Before writing here I made backups, locally and on github, like you taught me in the past :)Now I’ll try
That’s incredible… I did it, everything goes good… no issues but when I start it
npm start
[email protected] start
npm run start:x11[email protected] start:x11
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js[2025-05-11 22:44:21.593] [LOG] Starting MagicMirror: v2.31.0
[2025-05-11 22:44:21.682] [LOG] Loading config …
[2025-05-11 22:44:21.687] [LOG] config template file not exists, no envsubst
[2025-05-11 22:44:23.250] [INFO] Checking config file /home/MYMIRR/MagicMirror/config/config.js …
[2025-05-11 22:44:23.532] [INFO] Your configuration file doesn’t contain syntax errors :)
[2025-05-11 22:44:23.535] [INFO] Checking modules structure configuration …
[2025-05-11 22:44:23.824] [ERROR] _ is not definedAgain this _ is not defined
@nowayto wow!!! NOW i am really confused.
have you rebooted?
if you try the sample config.js
cd ~/MagicMirror/config mv config.js config.js.save cp config.js.sample config.js
and then
npm startdoes it run or fail
Sam… I don’t know how to saying it.
I figure out the issue.After your last message I tried what you suggest.
With the default cfg I had no errors, with mine I had errors.So I checked again and again the config…
and I find an underscore _ right at the start of the confignpm config:check told me “no syntax errors” and that confusing me.
When I edit it I use nano editor
I do “sudo nano config.js” and I press CTRL + _ to jump at the 250 line.
Might be one of the latest time I opened it and press _ a bit faster than CTRL and I add it for error.In addition I notice that when I open config.js with nano editor the green cursor is, clearly, at the start of the first line… EXACTLY on the undescore _ and it hides it.
I’m really sorry for bothering you with that.
How can I buy you a coffee ?
Thanks -
@nowayto no coffee needed, we found it!!!
please NEVER use sudo inside MagicMirror folder
no reason to use super user , just makes trouble laterso if you fix the config.js in the saved MagicMirror folder then it should run ok too!!!"
ill see what we can do about the misleading message… thanks for your energy here!!!
@nowayto i use ctrl-end on my keyboard for nano to get to end of file
haven’t found a way to do that on my chromebook, drives me crazy!!!
@nowayto ok, I’ve found the error producer
and I’ll propose a fix…I think this might have been more useful lol
[ERROR] fatal error in /home/sam/MagicMirror/config/config.js at line 19 column 1, _ is not defined
I opened
https://github.com/MagicMirrorOrg/MagicMirror/issues/3785for this issue
