    [ERROR] _ is not defined
    36 Posts 3 Posters 3.4k Views 3 Watching
      nowayto @sdetweil
      @sdetweil npm install results
      ~/MagicMirror $ npm install
      npm error code ENOTEMPTY
      npm error syscall rename
      npm error path /home/MYMIRR/MagicMirror/node_modules/es-abstract
      npm error dest /home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi
      npm error errno -39
      npm error ENOTEMPTY: directory not empty, rename ‘/home/MYMIRR/MagicMirror/node_modules/es-abstract’ -> ‘/home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi’
      npm error A complete log of this run can be found in: /home/MYMIRR/.npm/_logs/2025-05-10T06_40_55_661Z-debug-0.log
      Tried with sudo
      ~/MagicMirror $ sudo npm install
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: [email protected]
      npm error notsup Not compatible with your version of node/npm: [email protected]
      npm error notsup Required: {“node”:“>=22.14.0”}
      npm error notsup Actual: {“npm”:“11.2.0”,“node”:“v20.18.1”}
      npm error A complete log of this run can be found in: /root/.npm/_logs/2025-05-10T06_41_52_949Z-debug-0.log
      npm seems to see an old version of nodejs but:
      ~/MagicMirror $ node -v
      v22.15.0
      I don’t know what happened.
      If it can help I had first problem after the MMM-SolarPicture
      but I’ve just installed it and configured it through config.js… nothing more than usual…
      but the actual behaviour is that pm2 status says it’s running, but on the monitor I see just the raspbian desktop
      │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
      │ 0 │ mm │ default │ N/A │ fork │ 4311 │ 19s │ 64 │ online │ 0% │ 2.6mb │ ber… │ disabled │
        sdetweil @nowayto
        @nowayto two things
        doing test run = true, NO updates will be applied!
        upgrading from version 2.31.0 to 2.31.0
        doing test run changes nothing, its a safety check
        and i wont let you upgrade over the same release accidentally
        so you need to rerun the command and add
        force
        to the end
          sdetweil @sdetweil
          @nowayto NEVER use sudo with any npm command
          the number in the pm2 status 4311 is the number of restarts
          youve got a mess
          now we HAVE to use sudo to undo it
          cd ~/MagicMirror
          sudo rm -rf node_modules
          cd fonts
          cd ..\vendor
          sudo rm-rf node_modules
          cd ..
          lets see about node
          which node
          n
          q to quit
          nvm
          dont do anything else til we figure out the nodejs problem
            nowayto @sdetweil
            @sdetweil I’m sorry :(
            I did it what you suggest and config:check gave me a module error again. Different than one before
            npm run config:check
            [email protected] config:check
            node js/check_config.js
            node:internal/modules/cjs/loader:1404
            throw err;
            Error: Cannot find module ‘ajv’
            Require stack:
            After “require stack” there are other lines, if you need it, tell me.
              sdetweil @nowayto
              @nowayto
              i said stop
              we need to fix nodejs so npm install will work
              node -v
              says something
              and npm install says node is different
              i am trying to figure out where node is installed and by who
              system, nvm or n
              you didn’t give me answers to the commands i provided
                nowayto @sdetweil
                which node gave me
                /home/MYMIRR/.nvm/versions/node/v22.15.0/bin/node
                n gave me
                node/20.18.1
                Use up/down arrow keys to select a version, return key to install, d to delete, q to quit
                nvm gave me
                Node Version Manager (v0.39.5)
                Note: refers to any version-like string nvm understands. This includes :
                • full or partial version numbers, starting with an optional “v” (0.10, v0.1.2 , v1)
                • default (built-in) aliases: node, stable, unstable, iojs, system
                • custom aliases you define with nvm alias foo
                followed by a lot of options
                  sdetweil @nowayto
                  @nowayto ok nvm and n do the same function but differently
                  i use n in my scripts because it runs everywhere
                  so lets turn off nvm
                  nvm deactivate
                  nvm unload
                  cd ~
                  rm -rf  .nvm
                  now which node
                  should find /usr/local/bin/node
                  now we need n to get to node 22.14.0
                  sudo n 22.14.0
                  now node -v
                  should return 22.14.0
                  if so, do
                  cd  ~/MagicMirror
                  npm install
                  now MagicMirror should run
                    nowayto @sdetweil
                    @sdetweil Thank you a lot Sam.
                    I did everything but
                    I have an [ERROR] _ is not defined
                    [email protected] start:x11
                    DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                    [2025-05-11 15:39:26.429] [LOG] Starting MagicMirror: v2.31.0
                    [2025-05-11 15:39:26.527] [LOG] Loading config …
                    [2025-05-11 15:39:26.537] [LOG] config template file not exists, no envsubst
                    [2025-05-11 15:39:28.154] [INFO] Checking config file /home/MYMIRR/MagicM irror/config/config.js …
                    [2025-05-11 15:39:28.478] [INFO] Your configuration file doesn’t contain syntax errors :)
                    [2025-05-11 15:39:28.482] [INFO] Checking modules structure configuration …
                    [2025-05-11 15:39:28.793] [ERROR] _ is not defined
                      sdetweil @nowayto
                      @nowayto so that sounds like the npm install failed again
                      do it again and show the output
                        nowayto @sdetweil
                        installer didn’t failed, but this is the result now
                        npm install
                        [email protected] postinstall
                        npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                        [email protected] install-vendor
                        echo "Installing vendor files …
                        " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                        up to date in 7s
                        [email protected] install-fonts
                        echo "Installing fonts …
                        " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                        Installing fonts …
                        up to date in 3s
                        [email protected] prepare
                        [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                        up to date in 45s
                        285 packages are looking for funding
                        run npm fund for details
                        • 2 / 4
