    MMM-MyCalendar
    109 Posts 40 Posters 121.6k Views 38 Watching
      Fonfon @j.e.f.f
      @j-e-f-f said in MMM-MyCalendar:
      @Fonfon No, but you can add a background colour to the module to make the text stand out better. try something like this in your custom.css file:
      .MMM-MyCalendar .module-content {
        background-color: rgba(0,0,0,0.5);
      The first three parameters 0,0,0 mean black, and the fourth parameter 0.5 is the level of transparency. Specify a decimal between 0 and 1, where 0 is fully transparent, and 1 is fully opaque.
      Thanks j.e.f.f for your help !
        charp07 @zzaidi148
        @zzaidi148 @j-e-f-f
        I have this same issue and haven’t had any luck in resolving the issue. I even copied the recommended config from earlier in this forum. Is there something that I am missing?
        It will just say, “Loading…”
        			module: "MMM-MyCalendar",
        			position: "top_left",
        			classes: "default everyone",
        			header: "Upcoming",
        			disabled: false,
        				colored: true,
        				maximumNumberOfDays: 30,
        				maximumEntries: 5,
        				fade: false,
        				maxTitleLength: 500,
        				useRelativeDates: false,
        				dayOfWeekFormat: "dddd",
        				timeFormat: "h:mm A",
        				dateFormat: "MMMM D",
        				joiningWord: "at",
        				urgency: 1,
        				calendars: [
        					url: "https://calendar.google.com/calendar/ical path",
        					color: "#ffb350"
        					color: "#ff77d4"
          charp07 @charp07
          @charp07 figured it out! Sorry!
            BRSQUIRRL @j.e.f.f
            @j-e-f-f This feature (grouping by day) would be awesome! Have you had a chance to make any progress on this?
              rookiepilot
              Did anybody’s MMM-MyCalendar module break after daylight savings (Sunday November 3rd)? Both my “MMM-MyCalendar” AND “MMM-CalendarExt2” modules are showing events on the wrong days now. The problem seems to only occur with reoccurring events; they usually show up one day earlier. Rebooting does not correct the issue. I hope someone can figure this out soon 😞
                Clubjack @j.e.f.f
                @j-e-f-f
                Hey. I found your Module last days and i love it. Thanks for that.
                One question.
                I have one added calendar (holidays) that have a “description” in his calendar entry.
                So the Modul Shows three lines.
                First with the Titel (christmas),
                Second with date (24 Dezember)
                third with description (calovo.de).
                Is it possible to hide the description?
                • Alex2020A Offline
                  Alex2020
                  Salve ho installato oggi il modulo MMM-MyCalendar ma per cambiare le icone o i simboli ed assegnarle una diversa come si fa ?Potreste mettermi un esempio?Grazie.Inoltre è possibile cambiare colore esempio Martedi 5 Febbario rosso e Mercoledi 6 Febbraio in verde?Grazie.
                    eliah
                    Hi @j-e-f-f,
                    Thank you for the great module! :)
                    I have added an option to have a calendar label displayed before the event text as it looks more intuitive and does not require to remember colors :). If you are ok to have this added to your code I can either send the updates to you or create a pull request in github.
                    Here is the screenshot (I use MM as a picture frame, not a mirror, with bright colored image, that’s why it is black on white in my case):
                    alt text
                      PatrickGolfer @charp07
                      @charp07 What was the fix to your Loading issue?
                      • 10
                      • 11
                      • 11 / 11
