    MMM-MyCalendar
    109 Posts 40 Posters 121.6k Views 38 Watching
    • H Offline
      himanshulotia
      Just newbie over here. I have used MMM-Mycalendar module to show two different calendar on two separate area of the mirror (bottom_left & bottom_right)
      I want heading on each calendar to have different color and if possible icon as well.
      Is this possible?
      • twosquirrelsT Offline
        twosquirrels
        This module just won’t display a 2-column layout for me despite it being enabled in the config:
                module: "MMM-MyCalendar",
                header: "Family Calendar",
                position: "top_left",    // This can be any of the regions. Best results in left or right regions.
        colored: true,
        maximumEntries: 6,
        columns: true,
        showLocation: false,
        maxTitleLength: 200,
        fetchInterval: 120000,
        fade: false,
        calendars: [
          ninjabreadman @twosquirrels
          @twosquirrels Does MMM-MyCalendar support a column layout? I can’t find any reference to a columns property for its config: https://github.com/jclarke0000/MMM-MyCalendar/blob/master/README.md
          Problem with config or JavaScript? Copy/paste it into JSHint.
          Check out the detailed walkthroughs on install, config, modules, etc.
          twosquirrelsT 1 Reply Last reply Reply Quote 0
            twosquirrels @ninjabreadman
            @ninjabreadman Page 1 contains an update where it mentions support for 2 columns:
            https://forum.magicmirror.builders/topic/2559/mmm-mycalendar?page=1
            alt text
              ninjabreadman @himanshulotia
              @himanshulotia Yes.
              First, you can set colored: true in the config, then add color: "#d9b4b2” and color: "#a0cfe2" per the docs.
              Second, have a look at the FontAwesome 4 docs. You could likely insert them into your headings. For how to insert images, you could probably use CSS if you can find the right selectors.
                @twosquirrels It looks like you need to use the using_nunjucks branch. The default branch is still (it seems to me, on my phone) 1.0 – it doesn’t contain an .njk template file.
                  @ninjabreadman
                  Ahh, I see. Silly question - how do I pull from that branch instead of from the master? I googled the differences but it’s not making sense to me.
                  AHH! I figured it out:
                  pi@magicmirror:~/MagicMirror/modules $ git clone -b using_nunjucks https://github.com/jclarke0000/MMM-MyCalendar.git
                  Cloning into 'MMM-MyCalendar'...
                  remote: Counting objects: 84, done.
                  remote: Total 84 (delta 0), reused 0 (delta 0), pack-reused 84
                  Unpacking objects: 100% (84/84), done.
                  @ninjabreadman thank you for pointing this out!
                    smreid
                    Hi
                    Just wondering if there is anyway I can use custom symbols for calendar entries in place of the ‘day of the month’ logos? Similar to the default calendar module?
                    Stephen
                      cola0927
                      Hi, it’s really a nice module, but got a small issue here. I’m wondering how to make the event contents left-aligned. I tried to modify some parameters in MMM-MyCalendar.css, but didn’t work.
                      Thanks!
                      justjim1220J 1 Reply Last reply Reply Quote 0
                      • justjim1220J Offline
                        justjim1220 Module Developer @cola0927
                        @cola0927
                        change the text-align under title in the css
                        .MMM-MyCalendar .title {
                          color: #ff0;
                          font-size: 55px;
                          line-height: 115%;
                          font-weight: 600;
                          text-align: left;
                          padding-left: 0;
                          margin-bottom: 2px;
                          white-space: nowrap;
                          text-overflow: ellipsis;
                          border-radius: 15px;
                          overflow: hidden;
                          display: block;
                          margin-top: 4px;
                        "Life's Too Short To Dance With Ugly People"
                        Jim Hallock - 1995
                        • 10
                        • 11
                        • 8 / 11
