MMM-NOAA - Another Weather Module
@Pielo how did you make the frame with temperature and humidity? I would like to get something like this by sending data via mqtt
Hi everyone, this module looks really great. Is there a possibility not to show certain items such as AQI, UV etc.?
@msulzer Anything is possible LOL Just go in and edit them out of the getDom section then they can’t show.
If you need help let me know. I can whittle it down for you, PM me ;)
Dear cowboysdude,
thanks a lot for the great Module. I’m trying to implement it.
Just to know…totally new to it.Full install and config added. But now the MagicMirror staies black completally.
When i remove the config information, the Mirror is working nomarlly.Has this to do with the API’s?
Thanks for your help. -
@sdetweil thanks for your link.
but the Mirror is working without the MMM-NOAA-Another Weather Module activated.
As soons as i activate it, the screen stayes black.in the link i couldn’t find any solution.
Any other ideas?
Thanks. -
@n0v4 the topic posted defined work for you to do
when the screen is black, what do the messages say in the place u start MM.
either npm start or
pm2if pm2, then pm2 logs --lines=nnn show the results (nnn= number, default 15)
sorry…like i’ve said…totally new to the topic.i’m i right:
/home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
0|MagicMir | at require (internal/modules/cjs/helpers.js:88:18)
0|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:8:15)
0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:1078:30)
0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10) {
0|MagicMir | code: ‘MODULE_NOT_FOUND’,
0|MagicMir | requireStack: [
0|MagicMir | ‘/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js’,
0|MagicMir | ‘/home/pi/MagicMirror/js/app.js’,
0|MagicMir | ‘/home/pi/MagicMirror/js/electron.js’,
0|MagicMir | ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
0|MagicMir | undefined
0|MagicMir | ]
0|MagicMir | }
0|MagicMir | [29.11.2021 23:32.46.509] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|MagicMir | [29.11.2021 23:32.46.510] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues -
@n0v4 said in MMM-NOAA - Another Weather Module:
so, it IS the issue of the topic… u need to get a few more lines of output to identify the missing library
–lines=50
i went throu the link you’ve send before.
got the information “missing module request”.
just finished npm install request…all’s working.Great thanks a lot
