    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 364.8k Views 29 Watching
      Mykle1 Project Sponsor Module Developer
      Description:
      Up to the minute information about our Lunar partner, with a splash of EyeCandy, to boot!
      Update:
      Now with French translation. Other languages to follow, upon request.
      Download:
      [card:mykle1/MMM-Lunartic]
      Version 1.0.1
        Fonfon
        Hi !
        module work great but small mistakes
        here is the perfect french translation.
        Distance from Earth’s core = ": "Distance du noyau terrestre = ",
        "Distance from sun = ": "Distance du soleil = ",
        "The next full moon is ": "Prochaine pleine lune: ",
        "The next new moon is ": "Prochaine nouvelle lune: ",
        "The current moon is ": "La lune actuelle est a ",
        "The moon is “: “La lune est “,
        “% illuminated”: “% illuminée”,
        " days old”: " jours”,
        “waxing”: " croissante”,
        “waning”: “décroissante”,
        “When the Moon hits your eye . . .”: “Quand la lune frappe votre œil. . .”
        Other question the text is not perfectly under the animated picture but a little on the left.
        is it possible to modify that ?
        thanks Mykle1 ;)
        Mykle1M 3 Replies Last reply Reply Quote 0
          Mykle1 Project Sponsor Module Developer @Fonfon
          @Fonfon said in MMM-Lunartic:
          Good morning Fonfon,
          Take a look at the MMM-Lunartic.css file in your MMM-Lunartic folder. There you can change the color and positioning of every line of the module. You can also change the position of the animated picture, up, down, left, right. Ideally, you should copy and paste those entries into your custom.css file and do the editing there.
          Take a screenshot of the module, post it here, and tell me what you want to achieve.
          By default, all the text is aligned to the left text-align: left;. If you want to center the text under the animated picture, simply change all the text-align: left; to text-align: center;
            Fixed, thank you!
            git pull in the MagicMirror/modules/MMM-Lunartic folder for the corrected translation
                Update:
                The API I was using for this module is no longer available. What was I to do?
                Provide my own API. :^)
                So, along with the new API, there is a new config option to view an image of the appearance of the current moon, updated minutely. Courtesy of the U.S. Navy. Salute!
                Download:
                Version 1.0.2
                Example
                • T Offline
                  thetalentedfool
                  Noob questions!
                  1. When I pull the latest files, both the core .js files have Windows control characters in them. (I don’t think this is the source of my problems, but it seems maybe unintentional.)
                  2. My fresh stock MM install does not like the config files for this module. It’s the only custom module I’ve tried to add in this install. Whenever I add it to my main config, startup throws a config validation error and reverts to the default file. I’m having a hard time debugging it to provide a more precise error, since it’s just failing out at the initial validation stage. Any ideas how I can debug more precisely?
                  Thanks!
                  strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 1
                  • strawberry 3.141S Offline
                    strawberry 3.141 Project Sponsor Module Developer @thetalentedfool
                    @thetalentedfool you can put your config here so we can have a look
                      Mykle1 Project Sponsor Module Developer @thetalentedfool
                      @thetalentedfool said in MMM-Lunartic:
                      It’s not, but thank you for bringing that to my attention.
                      The problem is/was completely my fault. In a recent update to the repo, specifically the README file, I failed to place a comma at the end of the image: "animation" line of the config entry. I’ve updated the repo and apologize for the error. Your config entry should now look like this:
                              module: 'MMM-Lunartic',
                              position: 'top_left',                   // Best in left, center, or right regions
                      		image: "animation",                     // animation, current or static
                      		distance: "miles",                      // miles or km
                      		useHeader: false,                       // true if you want a header
                      		header: "The Lunartic is in my head",   // Any text you want
                      		maxWidth: "300px",
                      		animationSpeed: 3000,                   // updated info fades in and out
                      If you have any further problems or questions, don’t hesitate to post for assistance. Thanks!
                      Peace
                      T 1 Reply Last reply Reply Quote 0
                      • T Offline
                        thetalentedfool @Mykle1
                        @Mykle1 D’oh! Can’t believe I missed that too - my kingdom for an actual helpful nodejs debug message with pointers to the offending line. Works great now. Thanks for the response!
                        • 26
                        • 27
                        • 3 / 27
