    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 381.1k Views 29 Watching
      Mykle1 Project Sponsor Module Developer
      Minor update
      • Fixed wording for phases of the moon.
      • Also, a not so hidden config option for image choice.
      cd MagicMirror/modules/MMM-Lunartic
      git pull
      Or install as usual
        German translation added
        Thanks to our friend @tbbear, MMM-Lunartic now has German translation. And, when you choose German as your language, the date will be properly formatted for you. Again, thanks to @tbbear. Well done, Robert!
        git pull
        Or install as usual
        1 Reply Last reply Reply Quote 3
          It appears the API that I am using for this module has reached its limit for the month of November. I apologize for that. It’s actually my API being hosted by a free service herokuapp.com. The drawback is that it has such a low limitation. I’m not willing to pay for higher usage. So, as I see it, I have 2 options if I want to keep this module alive.
          1. I have the PHP file that does the computations for the API. I’d be willing to host the API if someone would be willing to help me set it up locally and administer it. That doesn’t seem very likely but the offer stands.
          2. I can look for another public API to use for the module. This is probably the more logical option but it’s not as cool as the first.
          So, to those millions of MMM-Lunartic users, I will start looking for another API this very moment. In the meantime, the module will be functional again on December 1 when the current API resumes.
            @tbbear
            API update
            I’ve acquired nearly double the amount of free API usage for my Lunartic module. So, no more loss of API in the 3rd week of every month. :-)
              So here we are on the 24th of January and my API for this module is still up and running. Miracle of miracles! With only 7 more days left in the month I still have 47% of my free dyno hours. Looks like this problem has been solved. :-)
                pepebc
                Hello, very interesting this module.
                I like Astronomy a lot, and I already have it installed. I have translated it into Spanish: es.json
                "Distance from Earth's core = ": "Distancia desde la Tierra: ",
                "Distance from sun = ": "Distancia desde el Sol: ",
                "The next full moon is ": "Próxima Luna llena ",
                "The next new moon is ": "Próxima Luna nueva: ",
                "The current moon is ": "La fase actual lleva ",
                "The moon is ": "Esta Luna está  ",
                "% illuminated": "% iluminada",
                " days old": " dias transcurridos",
                "New Moon Phase": "Luna Nueva",
                "Waxing Crescent Moon": "Luna Creciente",
                "First Quarter Half Moon": "Primer cuarto de media luna",
                "Waxing Gibbous Moon": "Luna creciente Gibosa",
                "Full Moon": "Luna Llena",
                "Waning Gibbous Moon": "Luna Gibosa menguante",
                "Third Quarter Half Moon": "Tercer cuarto de Media Luna",
                "Waning Crescent Moon": "Luna creciente menguante",
                "When the Moon hits your eye . . .": "Cuando la Luna ilumina tus ojos . . ."
                Mykle1M 1 Reply Last reply Reply Quote 2
                  Mykle1 Project Sponsor Module Developer @pepebc
                  @pepebc said in MMM-Lunartic:
                  Hello, and thank you. I applaud the fact that you made the effort and did the translations. :-)
                  I’ve added your translation file to the module. A git pull in the MMM-Lunartic directory will get you the updated files.
                  Once again, thanks!
                  Peace.
                    Thanks to user @el97 the module now has Swedish translation.
                      Download:
                      [card:mykle1/MMM-Lunartic]
                      Version Update 1.0.3
                      Added an option for rotating data. So now the module takes up far less mirror real estate yet you still get the same information. Of course, you can still use the static mode, in which case, the module is visually unchanged.
                      Click on the animated gif below for a more pleasing view:
                      Do a git pull in your MMM-Lunartic directory or install as per the readme.
                        Version update 1.0.4
                        Fixed the check for “Last full moon was” and "Next full moon is. That was bothering me.
                        Added config option for sound of howling wolf when there is a full moon.
                        git pull in the MMM-Lunartic directory or install as per the readme
                        https://github.com/mykle1/MMM-Lunartic
                        • 26
                        • 27
                        • 5 / 27
