    After update to Mirror to 2.1.3 - no working Whitlist
    33 Posts 18 Posters 22.1k Views 18 Watching
      Nick
      Yes, including my personal wiki on another Raspberry Pi, all with 2-5ms
      Mykle1M J 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @Nick
        @Nick said in After update to Mirror to 2.1.3 - no working Whitlist:
        None of this may help, but you can use it as a checklist.
        • ifconfig on Pi reports the IP address you are trying to ping (wlan0) assuming wifi
        • Connecting Pi via ethernet, ifconfig and trying to ping then
        • Pinging another device from the Pi itself
        • The MM software updates. Clock, calendar, weather, etc?
        Logically, if the only thing you can’t do is ping or connect to the Pi, then something is wrong on the software side, whether a corruption, an edit or a failed installation of the software or dependencies during the upgrade process. The answer in that case, with the most success, is a manual installation, IMHO. You can continue to troubleshoot, which could take a long time, or you can know in less than an hour. You will not lose anything in doing this.
        https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners
          Jopyth Moderator @Nick
          @Nick As @Mykle1 said: something is wrong if you can neither ping nor ssh. You definitely need to check your general wifi/ethernet setup. This is not something that can be solved through the config file.
          • FlatPepsiF Offline
            FlatPepsi
              ronanversendaal
              Just came across this post while troubleshooting this issue.
              I got it working by converting the ip range to CIDR format by using this page as mentioned in older posts. I added these ip’s to the whitelist (without the ::ffff: !) and it worked.
              It’s also important to set the address value to “0.0.0.0”
              • 2 / 4
