    After update to Mirror to 2.1.3 - no working Whitlist
    33 Posts 18 Posters 22.5k Views 18 Watching
    • MichMichM Offline
      MichMich Admin
      Hmm … that doesn’t sound good. Could one of you open an issue on https://github.com/MichMich/MagicMirror/issues?
      Make sure you fill in ALL te questions in the issue template.
      Thanks!
        d3r
        Had the same issue. added
        address:"0.0.0.0",
        to the config and it’s working again.
        https://github.com/MichMich/MagicMirror/issues/1036
        randomnoiseR 1 Reply Last reply Reply Quote 2
        • MichMichM Offline
          MichMich Admin
          Thanks d3r!
            roramirez Core Contributors
            That happens because the release 2.1.3 was introduced a new change to make more secure the MagicMirror, to prevent open all interfaces to world. So, now from 2.1.3 the default values for address is localhost instead of 0.0.0.0… so …be careful to set this value.
            Easy module development with MagicMirror Module Template
            Sandy2503S foxF 2 Replies Last reply Reply Quote 0
            • Sandy2503S Offline
              Sandy2503 @roramirez
              @roramirez - and how can i now access to my mirror from my homenetwork ?
              What do i have to do ???
              Sandy
              • randomnoiseR Offline
                randomnoise @d3r
                @d3r said in After update to Mirror to 2.1.3 - no working Whitlist:
                address:“0.0.0.0”,
                Thanks d3r, this was indeed the solution.
                foxF 1 Reply Last reply Reply Quote 1
                  roramirez Core Contributors @Sandy2503
                  @Sandy2503 said in After update to Mirror to 2.1.3 - no working Whitlist:
                  Set the IP address of your MagicMirror there.
                  • K Offline
                    knubbl
                    • foxF Offline
                      fox @randomnoise
                      @randomnoise said in After update to Mirror to 2.1.3 - no working Whitlist:
                      address:“0.0.0.0”,
                      And how is the syntax?
                      Something like this?
                      var config =
                              electronOptions: {
                              ipWhitelist: [
                                      "127.0.0.1",
                                      "0.0.0.0",
                                      "::ffff:127.0.0.1",
                                      "::1",
                                      "::ffff:192.168.188.42",
                                      "192.168.188.1/24",
                                      "::ffff:192.168.188.50"
                      that does not work for me, before the update my MM was working really fine.
                      Also MMM-iFrameReload is not working anymore :(
                      Issues With MMM-WatchDog known?
                      https://forum.magicmirror.builders/post/29827
                      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                      randomnoiseR 1 Reply Last reply Reply Quote 0
                        randomnoise @fox
                        @fox this doesn’t go within the whitelist section it has to go after the comma at the end of your whitelist section.
                        It is its own config parameter.
                        address:“0.0.0.0”,
                        • 1 / 4
