Sync private iCloud calendar with MagicMirror
A while ago, I posted a thread for syncing an iCloud calendar with MagicMirror. Unfortunately this solution was just a workaround and you needed to use a Mac which is also synced with your calendar. It was far from being a nice solution.
I just found out that the tool I was using (
vdirsyncer
) also supports syncing with iCloud. I wrote a detailed walkthrough for this.I’ll re-post this part from the original post:
Why doing it this way?
I don’t want my calendar to be available via a public URL like mentioned in the iCloud calendar thread. Even though the public sharing address is quite long, web crawlers can still find them and your private life is publicly available. I just don’t like that scenario. So I wanted a solution that uses encryption and authentication against all services.
So here’s a really nice solution to sync the mirror with iCloud (privately):
Get app-specific password from iCloud
vdirsyncer
needs an app-specific password to connect to iCloud. You can create one in your AppleID settings like descibed in Apple’s support document for using app-specific passwords: https://support.apple.com/en-us/HT204397Create one and write it down for later.
Install and set up
vdirsyncer
vdirsyncer
needs to be installed on the machine that hosts your mirror software. On my raspbian system,vdirsyncer
was not available viaapt
. So I hat to install it viapip
.Installation of
vdirsyncer
Now we get
vdirsyncer
and it’s dependencies:sudo apt-get install libxml2 libxslt1.1 zlib1g python3 pip3 install --user --ignore-installed vdirsyncer
(This is the quick and easy way, it should suffice for most users. For a more clean way to install it, please refer to https://vdirsyncer.pimutils.org/en/stable/installation.html#the-clean-hard-way)
Now, change the first line of your
vdirsyncer
executable to use onlypython3
:nano ~/.local/bin/vdirsyncer
And change the first line to
#!/usr/bin/python3
I needed to create a symlink to the vdirsyncer executable. So we’re doing this:
sudo ln -s /home/pi/.local/bin/vdirsyncer /usr/bin/vdirsyncer
Now you should be able to use the
vdirsyncer
command from the command line.Create a folder for the calendar file
As mentioned in this post, we can put the calendar file into the modules folder to access it via the calendar module. So we create a folder for our calendars:
mkdir /home/pi/MagicMirror/modules/calendars
Configure
vdirsyncer
Create a config file in
~/.vdirsyncer/config
and open it withnano
:mkdir ~/.vdirsyncer touch ~/.vdirsyncer/config nano ~/.vdirsyncer/config
Here’s an example configuration to use with iCloud. Just copy it into your opened file in
nano
and enter your iCloud credentials.# vdirsyncer configuration for MagicMirror. # # Move it to ~/.vdirsyncer/config or ~/.config/vdirsyncer/config and edit it. # Run `vdirsyncer --help` for CLI usage. # # Optional parameters are commented out. # This file doesn't document all available parameters, see # http://vdirsyncer.pimutils.org/ for the rest of them. [general] # A folder where vdirsyncer can store some metadata about each pair. status_path = "~/.vdirsyncer/status/" # CALDAV Sync [pair iCloud_to_MagicMirror] a = "Mirror" b = "iCloud" collections = ["HERE-GOES-THE-UUID-OF-THE-CALENDAR-YOU-WANT-TO-SYNC"] # Calendars also have a color property metadata = ["displayname", "color"] [storage Mirror] # We need a single .ics file for use with the mirror (Attention! This is really slow on big amounts of events.) type = "singlefile" # We'll put the calendar file to a readable location for the calendar module path = "/home/pi/MagicMirror/modules/calendars/%s.ics" [storage iCloud] type = "caldav" url = "https://caldav.icloud.com/" # Authentication credentials username = "YOUR-ICLOUD-EMAIL-ADDRESS" password = "HERE-GOES-YOUR-APP-SPECIFIC-ICLOUD-PASSWORD" # We only want to sync in the direction TO the mirror, so we make iCloud readonly read_only = true # We only want to sync events item_types = ["VEVENT"] # We need to keep the number of events low, so we'll just sync the next month # Adjust this to your needs start_date = "datetime.now() - timedelta(days=1)" end_date = "datetime.now() + timedelta(days=30)"
Make sure, you use the
start_date
andend_date
parameters to keep the number of calendar events low. I tried syncing with 700+ events and it is really really sloooooow! Especially when using thesinglefile
option for the mirror.Add your iCloud credentials like shown in the config file.
Running
vdirsyncer
as a systemd.timer for automatic syncInstall the
vdirsyncer.service
andvdirsyncer.timer
files to/etc/systemd/user
:curl https://raw.githubusercontent.com/pimutils/vdirsyncer/master/contrib/vdirsyncer.service | sudo tee /etc/systemd/user/vdirsyncer.service curl https://raw.githubusercontent.com/pimutils/vdirsyncer/master/contrib/vdirsyncer.timer | sudo tee /etc/systemd/user/vdirsyncer.timer
By default, the syncer is started every 15 minutes. You can change it by configuring the times in the
vdirsyncer.timer
file:sudo nano /etc/systemd/user/vdirsyncer.timer
Now we activate the timer in systemd:
systemctl --user enable vdirsyncer.timer
Let
vdirsyncer
discover the collections and do the inital syncNow, we have to find out, which collection we want to sync. Let
vdirsyncer
discover everything:vdirsyncer discover
You should get an output like this (depending on the number of calendars you have in iCloud):
Discovering collections for pair iCloud_to_MagicMirror Mirror: iCloud: - "25CB285C-E163-4E0E-B420-C3FB469B7C00" ("Calendar 1") - "9221FEE8-E8B4-4D07-9402-8638529919EC" ("Calendar 2") - "953A5477-E405-4ED6-A5C3-473444EACC95" ("Calendar 3") warning: No collection "HERE-GOES-THE-UUID-OF-THE-CALENDAR-YOU-WANT-TO-SYNC" found for storage Mirror. Should vdirsyncer attempt to create it? [y/N]:
Choose
N
for now and pressreturn
Now replace theHERE-GOES-THE-UUID-OF-THE-CALENDAR-YOU-WANT-TO-SYNC
in the config with the UUID of the calendar you want to sync.
We assume, we want to sync “Calendar 2”.So line 19 of your config should look like this:
collections = ["9221FEE8-E8B4-4D07-9402-8638529919EC"]
Now, we can run the discover again and make the first sync:
vdirsyncer discover
You should get something loke this:
Discovering collections for pair iCloud_to_MagicMirror Mirror: iCloud: - "25CB285C-E163-4E0E-B420-C3FB469B7C00" ("Calendar 1") - "9221FEE8-E8B4-4D07-9402-8638529919EC" ("Calendar 2") - "953A5477-E405-4ED6-A5C3-473444EACC95" ("Calendar 3") warning: No collection "9221FEE8-E8B4-4D07-9402-8638529919EC" found for storage Mirror. Should vdirsyncer attempt to create it? [y/N]:
Choose
y
and pressenter
. Now we can start the sync with:vdirsyncer sync
You should find a single calendar file in
with the UUID of your calendar as filename like221FEE8-E8B4-4D07-9402-8638529919EC.ics
in this example.Add the calendar file to the calendar module of the mirror
Now, we just have to add the URL to the calendar file to our calendar module of the mirror like this:
{ module: 'calendar', position: 'top_left', // This can be any of the regions. Best results in left or right regions. config: { maximumNumberOfDays: 10, maximumEntries: 7, calendars: [ { url: 'http://localhost:8080/modules/calendars/221FEE8-E8B4-4D07-9402-8638529919EC.ics', symbol: 'calendar' } ] } },
If everything went well, your MagicMirror is now automatically syncing your iCloud calendar with it’s calendar module :)
Does this allow the option for different icons for different calenders? I’m just starting to build mine and would like to sync two seperate iCloud calenders and have them display with different icons/colours
Yes, this should allow multiple coloured calendars.
You just have to add the UUIDs for each calendar you want to sync to thecollections
array in yourvdirsyncer
config.
This should create multiple.ics
files. One for each calendar. Then you could add each calendar to your MagicMirror config and use thecolor
option described in the default calendar module for your calendars. Just add thecolored
option to your “global” module config and add acolor
option to each calendar.A calendar config could look like this then (for “Calendar 1” and “Calendar 2” as described above):
{ module: 'calendar', position: 'top_left', // This can be any of the regions. Best results in left or right regions. config: { colored: true, // Activate coloring maximumNumberOfDays: 10, maximumEntries: 7, calendars: [ // "Calendar 1" { url: 'http://localhost:8080/modules/calendars/25CB285C-E163-4E0E-B420-C3FB469B7C00.ics', symbol: 'calendar' color: '#123456' // Assign color }, // "Calendar 2" { url: 'http://localhost:8080/modules/calendars/221FEE8-E8B4-4D07-9402-8638529919EC.ics', symbol: 'calendar' color: '#ABCDEF1' // Assign color } ] } },
hello how do we get the links calendars icloud thank you
@Doubleve What do you mean?
I will like my 3 calendars icloud but I do not see the links of the style
https://p02calendars.icloud.com/published/2/xxxxxxxxxxxxxxxxxxxxxQhtoAvoFiIwGI1
To have UUID -
@Doubleve You don’t need these links, since
vdircsyncer
discovers your calendars automatically on iCloud and identifies them by their IDs.It is explained in the “Let
vdirsyncer
discover the collections and do the inital sync” section of the walkthrough.You mirror accesses the calendar saved to a file on your mirror.
@Beh error for discover
Traceback (most recent call last):
File “/usr/bin/vdirsyncer”, line 7, in
from vdirsyncer.cli import main
ImportError: No module named ‘vdirsyncer’ -
@Doubleve Did you change the first line of the file to
#!/usr/bin/python3
everything is good
