MMM-PIR-Sensor Guide with Edits and Updates
@dubalda can you elaborate more detailed the failure, e.g, error message or similar?
I am curious to know if there is a benefit by using the MM-Module for the PIR vs. the executable script which can be autostarted with pm2 (as per this tutorial). Can anyone help?
@Fozi thank you for coming back to me. Here are the error messages I’m getting…apologies if it’s quite long! I unfortunately wasn’t able to upload the log file.
pi@pi:~/MagicMirror/modules/MMM-PIR-Sensor $ git pull
Updating be81cf0…d4831f2
Fast-forward
README.md | 14 ++++++++++++++
node_helper.js | 46 ++++++++++++++++++++++++++++++++++++++++++++±
2 files changed, 59 insertions(+), 1 deletion(-)
pi@pi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install[email protected] postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
electron-rebuild -e …/…/node_modules/electronâ Rebuild Failed
An unhandled error occurred inside electron-rebuild
make: Entering directory ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi-2019/build’
CXX(target) Release/obj.target/wiringPi/src/addon.o
In file included from /home/pi/.electron-gyp/6.1.7/include/node/v8-internal.h:14,
from /home/pi/.electron-gyp/6.1.7/include/node/v8.h:25,
from …/src/addon.h:4,
from …/src/addon.cc:1:
/home/pi/.electron-gyp/6.1.7/include/node/v8config.h:326:49: warning: ‘MicrotasksCompletedCallback’ is deprecated [-Wdeprecated-declarations]
declarator attribute((deprecated(message)))
/home/pi/.electron-gyp/6.1.7/include/node/v8.h:8205:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
V8_DEPRECATE_SOON("Use WithData version.",
/home/pi/.electron-gyp/6.1.7/include/node/v8.h:8214:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
In file included from …/src/addon.cc:1:
…/src/addon.h:12:28: error: ‘Handle’ is not a member of ‘v8’
bool HasInstance(v8::Handlev8::Value val);
…/src/addon.h:12:44: error: expected primary-expression before ‘>’ token
…/src/addon.h:12:46: error: ‘val’ was not declared in this scope
…/src/addon.h:13:28: error: redefinition of ‘bool node::Buffer::HasInstance’
bool HasInstance(v8::Handlev8::Object val);
…/src/addon.h:12:12: note: ‘bool node::Buffer::HasInstance’ previously defined here
…/src/addon.h:13:28: error: ‘Handle’ is not a member of ‘v8’
…/src/addon.h:13:45: error: expected primary-expression before ‘>’ token
…/src/addon.h:13:47: error: ‘val’ was not declared in this scope
…/src/addon.h:14:22: error: ‘Handle’ is not a member of ‘v8’
char Data(v8::Handlev8::Value val);
…/src/addon.h:14:38: error: expected primary-expression before ‘>’ token
…/src/addon.h:14:40: error: ‘val’ was not declared in this scope
char* Data(v8::Handlev8::Value val);
…/src/addon.h:15:22: error: redefinition of ‘char* node::Buffer::Data’
char* Data(v8::Handlev8::Object val);
…/src/addon.h:14:13: note: ‘char* node::Buffer::Data’ previously defined here
…/src/addon.h:15:22: error: ‘Handle’ is not a member of ‘v8’
…/src/addon.h:15:39: error: expected primary-expression before ‘>’ token
…/src/addon.h:15:41: error: ‘val’ was not declared in this scope
…/src/addon.h:16:25: error: ‘Handle’ is not a member of ‘v8’
size_t Length(v8::Handlev8::Value val);
…/src/addon.h:16:41: error: expected primary-expression before ‘>’ token
…/src/addon.h:16:43: error: ‘val’ was not declared in this scope
…/src/addon.h:17:25: error: redefinition of ‘size_t node::Buffer::Length’
size_t Length(v8::Handlev8::Object val);
…/src/addon.h:16:14: note: ‘size_t node::Buffer::Length’ previously defined here
…/src/addon.h:17:25: error: ‘Handle’ is not a member of ‘v8’
…/src/addon.h:17:42: error: expected primary-expression before ‘>’ token
…/src/addon.h:17:44: error: ‘val’ was not declared in this scope
…/src/addon.cc: In function ‘void throw_error(v8::Isolate*, const char*, …)’:
…/src/addon.cc:35:90: error: no matching function for call to ‘v8::Exception::Error(v8::MaybeLocalv8::String)’
isolate->ThrowException(v8::Exception::Error(v8::String::NewFromUtf8(isolate, buffer)));
In file included from …/src/addon.h:4,
/home/pi/.electron-gyp/6.1.7/include/node/v8.h:6538:23: note: candidate: ‘static v8::Localv8::Value v8::Exception::Error(v8::Localv8::String)’
static Local Error(Local message);
/home/pi/.electron-gyp/6.1.7/include/node/v8.h:6538:23: note: no known conversion for argument 1 from ‘v8::MaybeLocalv8::String’ to ‘v8::Localv8::String’
make: *** [wiringPi.target.mk:147: Release/obj.target/wiringPi/src/addon.o] Error 1
make: Leaving directory ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi-2019/build’
gyp ERR! build error
gyp ERR! stack Error:make
failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:198:13)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
gyp ERR! System Linux 4.19.118-v7l+
gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/.bin/node-gyp” “rebuild” “–target=6.1.7” “–arch=arm” “–dist-url=https://www.electronjs.org/headers” “–build-from-source”
gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi-2019
gyp ERR! node -v v10.21.0
gyp ERR! node-gyp -v v6.1.0
gyp ERR! not okFailed with exit code: 1
Error: make: Entering directory ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi-2019/build’
at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/spawn-rx/lib/src/index.js:267:84)
at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:205:16)
at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:156:26)
at Subscriber._error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
at Subscriber.error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/spawn-rx/lib/src/index.js:242:65)
at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:143:22)
npm ERR! code ELIFECYCLE
npm ERR! errno 255
npm ERR! [email protected] postinstall:electron-rebuild -e ../../node_modules/electron
npm ERR! Exit status 255
npm ERR!
npm ERR! Failed at the [email protected] postinstall script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.npm ERR! A complete log of this run can be found in:
npm ERR! /home/pi/.npm/_logs/2020-07-16T09_45_07_608Z-debug.log
[0_1595277021862_PIR-Sensor Error logs.txt](Uploading 100%) -
I‘d delete the module and re-install it. Obviously you haven’t changed any code (no info on stashing in the log). Your configuration will not be affected when you delete the module, it‘ll persist in config. js.
- stop all processes with entering pm2 stop all.
- cd to the module folder and enter: sudo rm -R MMM-PIR-Sensor. This will recursively remove the MMM-PIR-Sensor folder and it’s contents.
- Re-install the module as described on GitHub. The installation build process should run through without errors.
- Reboot
@Fozi rm -rf foldername will recursively remove all folders and content from foldername
@sdetweil looks like the wrong compiler level being used for the recompile.
Thanks guys, sorry for the late response! It’s the summer holidays so I’ve been doing daddy day care. I’ll try removing the module and reinstalling it. I’ll keep you posted.
@Feedy88
Works with out any problems, much better solution then MMM-PIR-Sensor.
Thanks -
Please no ads of any of my modules
If no one respect this rules. I will make private it -
@bugsounet my apologies. I have deleted the post.
