    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 128.3k Views 20 Watching
    • I Offline
      ianperrin
      @MichMich - some great ideas, keep them coming.
      I’ve created issues (or rather enhancements) for these on GitHub - https://github.com/ianperrin/MMM-ModuleScheduler/issues. Feel free to review, comment etc.
      • Mr.MeeseeksM Offline
        Mr.Meeseeks
        Is it required to restart mm/server if a scheduler configuration is changed, add, removed?
        CAAAAN DOO!👍
        I 1 Reply Last reply Reply Quote 0
        • I Offline
          ianperrin @Mr.Meeseeks
          @Mr.Meeseeks Apologies for missing this one.
          The schedules are set up after the ALL_MODULES_STARTED or DOM_OBJECTS_CREATED notifications have been received from the core. So a restart should not be required and a refresh of the browser should be sufficient to pick up config changes.
            cowboysdude Module Developer
            In retrospect I only wanted to be able to hide a module now and then LOL
            NEVER thought it would turn into such an awesome module!!!
            Thanks @ianperrin !!!
            • MitchfarinoM Offline
              Mitchfarino Module Developer
              @cowboysdude @ianperrin how would would I implement a schedule so that a module appeared for 5 minutes, then disappear and reappear in 5 minutes time?
              I’ve tried this
              module_schedule: { */5 * * * * },
              2nd edit- I thought I’d got it with this…
              module_schedule: { from: '*/2 * * * *', to: '*/3 * * * *'},
              cowboysdudeC I 2 Replies Last reply Reply Quote 0
                cowboysdude Module Developer @Mitchfarino
                @Mitchfarino said in MMM-ModuleScheduler:
                I’ve tried this
                Yes that should make it run every five minutes…
                Copy and try this without brackets…
                '*/5 * * * *'
                example - schedule: ‘30 9 * * *’,
                • I Offline
                  ianperrin @Mitchfarino
                  Try this
                  module_schedule: {from: '0/10 * * * *',  to: '5/10 * * * *'},
                  Which should equate to the module being
                  • shown every 10 minutes starting from 0 minutes past the hour, i.e. 0, 10, 20 etc
                  • hidden every 10 minutes starting from 5 minutes past the hour, i.e. 5, 15, 25 etc
                  MitchfarinoM 1 Reply Last reply Reply Quote 1
                    Mitchfarino Module Developer @ianperrin
                    @ianperrin cheers mate!
                    I’ll have a look tonight!
                    Fantastic module by the way
                    • I Offline
                      Thank you and no worries.
                      Unfortunately, I’ve just done a quick test with the expressions I posted above and they didn’t work. :(
                      If you check the cron expressions i suggested using crontab.guru, it would appear they are non-standard. Therefore, I suspect they are not supported by the node cron module.
                      Not to worry, there’s always a solution! crontab.org states that step values can be used in conjunction with ranges. So the expressions I believe you require are as follows:
                      module_schedule: {from: '0-59/10 * * * *',  to: '5-59/10 * * * *'},
                      • MichMichM Offline
                        MichMich Admin
                        Any ETA for https://github.com/ianperrin/MMM-ModuleScheduler/issues/4 and https://github.com/ianperrin/MMM-ModuleScheduler/issues/6?
                        • 4 / 9
