    274 Posts 78 Posters 709.1k Views 77 Watching
      pepebc @Jopyth
      @Jopyth
      Hello, excellent module. I have built the translation file into Spanish: es.json
      you want it?
        Jopyth Moderator @pepebc
        @pepebc Sure. Can you make a PR?
        @pyrosmiley Did you start using the brightness adjustment? That definitely overrides brightness of headers and text. Maybe reset to default? That should solve the problem.
        pyrosmileyP 1 Reply Last reply Reply Quote 1
        • emloweE Offline
          emlowe Module Developer
          This module is great - a couple items related to support for the ‘official 7" pi touchscreen’
          I can probably code this up and submit a PR if you want - the on/off is easy to do because that is already in the helper. Brightness would need to get moved to the helper away from the CSS tricks.
          It is interesting that controlling the brightness of a monitor itself over HDMI is surprisingly non-existent, but the 7" touchscreen h/w rev: 1.1 does indeed support direct brightness manipulation:
          You can control the brightness of the backlight itself by:
          echo X > /sys/class/backlight/rpi_backlight/brightness
          where X is a value between 0 and 255
          And you can turn off the backlight with
          echo 0 > /sys/class/backlight/rpi_backlight/bl_power
          and turn it back on with:
          echo 1 > /sys/class/backlight/rpi_backlight/bl_power
          Earle
          • pyrosmileyP Offline
            pyrosmiley @Jopyth
            @Jopyth I didn’t think I had (actually I don’t think I ever even noticed it!) but I guess I bumped into it just enough to change the value. All good now. Thanks!
              nobita @Jopyth
              @Jopyth What Happen , When Press menu “Edit config.js”,The Error show like this
              How to solve it,Thnaks so much
                Jopyth Moderator @nobita
                @nobita It is not an error, just a warning. You can use it, but make sure to make a backup of your config.js file first.
                Also new release with the long overdue french translation (which might need some improvements - I do not know, PRs are welcome if you spot anything):
                [1.1.5] - 2018-05-14
                Added
                • French translation
                Fixed
                • Updated documentation to new MagicMirror version
                • Fix error on updating MagicMirror
                  nobita @Jopyth
                  @jopyth Thank so much
                  • justjim1220J Offline
                    justjim1220 Module Developer
                    very cool.
                    question… can you get this to work using touch screen?
                    like the buttons you show on the screen, control them using touch instead of mouse pointer or keyboard?
                    "Life's Too Short To Dance With Ugly People"
                    Jim Hallock - 1995
                      Jopyth Moderator @justjim1220
                      @justjim1220 This is intended to be used from a different device (i.e. not your MagicMirror), for example, your smartphone or tablet. Maybe you could get it to work on your MagicMirror with something like the IFrame module and a touchscreen?
                      D 1 Reply Last reply Reply Quote 1
                        dmwilsonkc @Jopyth
                        @jopyth I just want to thank you again for your work on this module! Your module rocks!
                        BTW - It doesn’t have to be a mobile/tablet, I wrote an AI skill for Mycroft that uses your MMM-Remote-Control module to pass verbal commands to the MagicMirror.
                        If you’d like, check out the 2 min. video here.
                        And here’s a link to the repo if anyone would like to check out the Python code that interacts with the MMM-Remote-Control module.
                        Thanks again!
                        Cheers!
                        • 20
                        • 21
                        • 22
                        • 23
                        • 24
                        • 27
                        • 28
                        • 22 / 28
