    274 Posts 78 Posters 754.3k Views 77 Watching
      nobita @Jopyth
      @Jopyth What Happen , When Press menu “Edit config.js”,The Error show like this
      How to solve it,Thnaks so much
        Jopyth Moderator @nobita
        @nobita It is not an error, just a warning. You can use it, but make sure to make a backup of your config.js file first.
        Also new release with the long overdue french translation (which might need some improvements - I do not know, PRs are welcome if you spot anything):
        [1.1.5] - 2018-05-14
        Added
        • French translation
        Fixed
        • Updated documentation to new MagicMirror version
        • Fix error on updating MagicMirror
          nobita @Jopyth
          @jopyth Thank so much
          • justjim1220J Offline
            justjim1220 Module Developer
            very cool.
            question… can you get this to work using touch screen?
            like the buttons you show on the screen, control them using touch instead of mouse pointer or keyboard?
            "Life's Too Short To Dance With Ugly People"
            Jim Hallock - 1995
              Jopyth Moderator @justjim1220
              @justjim1220 This is intended to be used from a different device (i.e. not your MagicMirror), for example, your smartphone or tablet. Maybe you could get it to work on your MagicMirror with something like the IFrame module and a touchscreen?
              D 1 Reply Last reply Reply Quote 1
                dmwilsonkc @Jopyth
                @jopyth I just want to thank you again for your work on this module! Your module rocks!
                BTW - It doesn’t have to be a mobile/tablet, I wrote an AI skill for Mycroft that uses your MMM-Remote-Control module to pass verbal commands to the MagicMirror.
                If you’d like, check out the 2 min. video here.
                And here’s a link to the repo if anyone would like to check out the Python code that interacts with the MMM-Remote-Control module.
                Thanks again!
                Cheers!
                  BluP Project Sponsor @Snille
                  @snille
                  Hi snille,
                  Have you ever found a solution? I want to do something similar, but was also not able to get a module to be hidden/shown during certain times using MMM-ModuleScheduler
                  I tried
                  {notification: 'REMOTE_ACTION', schedule:  '*/2 * * * MON-FRI', payload: {action: "SHOW&module=module_15_MMM-Traffic"}},
                  {notification: 'REMOTE_ACTION', schedule:  '1-59/2 * * * MON-FRI', payload: {action: "HIDE&module=module_15_MMM-Traffic"}}
                  Does not make real sense, switching on a module every other minute, but would have been nice for testing…
                  If I use this as a GET request via HTTP,
                  http://My_MM_IP:8080/remote?action=HIDE&module=module_16_MMM-Traffic
                  it works like charm…also curl works using another Raspi sending this command to the MM
                  Any idea?
                  Thanks, Peter
                    PaulB
                    Dear MM-Builders,
                    does someone know how to solve attached problem?
                    Thanks in advace :-)
                    Hein-JanH 1 Reply Last reply Reply Quote 0
                    • Hein-JanH Offline
                      Hein-Jan @PaulB
                      @paulb
                      Is your device listed in “whitelist”, in your config.js?
                      Please check forum on whitelist issues.
                      Hein-Jan
                        m0111k
                        @jopyth in light of topic resurrection, I’m looking into creating multiple functions for my pi’s. I’m using MMM-NetworkScanner and MMM-Remote-Control. The idea is like follows:
                        When I leave home, my mobile goes offline from home network. I’m looking for a command to enable camera (reboot y/n) to enable another project I’d like to combine with this. (Pi Camera Notifier: https://iotbreaks.com/build-a-camera-alert-application-with-raspberrypi-3-and-iosandroid-pushbullet-app/) turning it into a security cam. The commands available in the readme of MMM-RC didnt hand me a clue for further investigations
                        I’d love to see these work in conjunction that’d give it a whole new dimension :)
                        • 27
                        • 28
                        • 2 / 28
