    274 Posts 78 Posters 725.2k Views 77 Watching
      nobita @Jopyth
      @jopyth Thank so much
      • justjim1220J Offline
        justjim1220 Module Developer
        very cool.
        question… can you get this to work using touch screen?
        like the buttons you show on the screen, control them using touch instead of mouse pointer or keyboard?
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
          Jopyth Moderator @justjim1220
          @justjim1220 This is intended to be used from a different device (i.e. not your MagicMirror), for example, your smartphone or tablet. Maybe you could get it to work on your MagicMirror with something like the IFrame module and a touchscreen?
          D 1 Reply Last reply Reply Quote 1
            dmwilsonkc @Jopyth
            @jopyth I just want to thank you again for your work on this module! Your module rocks!
            BTW - It doesn’t have to be a mobile/tablet, I wrote an AI skill for Mycroft that uses your MMM-Remote-Control module to pass verbal commands to the MagicMirror.
            If you’d like, check out the 2 min. video here.
            And here’s a link to the repo if anyone would like to check out the Python code that interacts with the MMM-Remote-Control module.
            Thanks again!
            Cheers!
              BluP Project Sponsor @Snille
              @snille
              Hi snille,
              Have you ever found a solution? I want to do something similar, but was also not able to get a module to be hidden/shown during certain times using MMM-ModuleScheduler
              I tried
              {notification: 'REMOTE_ACTION', schedule:  '*/2 * * * MON-FRI', payload: {action: "SHOW&module=module_15_MMM-Traffic"}},
              {notification: 'REMOTE_ACTION', schedule:  '1-59/2 * * * MON-FRI', payload: {action: "HIDE&module=module_15_MMM-Traffic"}}
              Does not make real sense, switching on a module every other minute, but would have been nice for testing…
              If I use this as a GET request via HTTP,
              http://My_MM_IP:8080/remote?action=HIDE&module=module_16_MMM-Traffic
              it works like charm…also curl works using another Raspi sending this command to the MM
              Any idea?
              Thanks, Peter
                PaulB
                Dear MM-Builders,
                does someone know how to solve attached problem?
                Thanks in advace :-)
                Hein-JanH 1 Reply Last reply Reply Quote 0
                • Hein-JanH Offline
                  Hein-Jan @PaulB
                  @paulb
                  Is your device listed in “whitelist”, in your config.js?
                  Please check forum on whitelist issues.
                  Hein-Jan
                    m0111k
                    @jopyth in light of topic resurrection, I’m looking into creating multiple functions for my pi’s. I’m using MMM-NetworkScanner and MMM-Remote-Control. The idea is like follows:
                    When I leave home, my mobile goes offline from home network. I’m looking for a command to enable camera (reboot y/n) to enable another project I’d like to combine with this. (Pi Camera Notifier: https://iotbreaks.com/build-a-camera-alert-application-with-raspberrypi-3-and-iosandroid-pushbullet-app/) turning it into a security cam. The commands available in the readme of MMM-RC didnt hand me a clue for further investigations
                    I’d love to see these work in conjunction that’d give it a whole new dimension :)
                      robiv8
                      Hallo, my remote control work.
                      but
                      When I pull the restart button the MagicMirror restarts fine but I become a Fehler (Fail)
                      What can this be?
                      My Log after push the button:
                      0|mm  | Shutting down server...
                      0|mm  | Stopping module helper: MMM-Page-Selector
                      0|mm  | Stopping module helper: MMM-Remote-Control
                      0|mm  | Stopping module helper: MMM-DWD-WarnWeather
                      0|mm  | Stopping module helper: MMM-PublicTransportHafas
                      0|mm  | Stopping module helper: newsfeed
                      0|mm  | Stopping module helper: MMM-Buttons
                      0|mm  | Use --update-env to update environment variables
                      0|mm  | [PM2] Applying action restartProcessId on app [mm](ids: 0)
                      0|mm  | { Error: Command failed: pm2 restart mm
                      0|mm  |     at ChildProcess.exithandler (child_process.js:287:12)
                      0|mm  |     at emitTwo (events.js:126:13)
                      0|mm  |     at ChildProcess.emit (events.js:214:7)
                      0|mm  |     at maybeClose (internal/child_process.js:925:16)
                      0|mm  |     at Socket.stream.socket.on (internal/child_process.js:346:11)
                      0|mm  |     at emitOne (events.js:116:13)
                      0|mm  |     at Socket.emit (events.js:211:7)
                      0|mm  |     at Pipe._handle.close [as _onclose] (net.js:554:12)
                      0|mm  |   killed: false,
                      0|mm  |   code: null,
                      0|mm  |   signal: 'SIGINT',
                      0|mm  |   cmd: 'pm2 restart mm' }
                      0|mm  | > [email protected] start /home/pi/MagicMirror
                      0|mm  | > sh run-start.sh
                      0|mm  | Starting MagicMirror: v2.6.0
                      0|mm  | Loading config ...
                      • swvalentiS Offline
                        swvalenti Project Sponsor
                        Same error as above but in English. Def restarts MM with no issue but MM RM displays error oddly?
                        • 24
                        • 25
                        • 26
                        • 27
                        • 28
                        • 26 / 28
