    MMM-AssistantMk2 problems when using electron-rebuild
    40 Posts 6 Posters 17.4k Views 6 Watching
      A Former User @dvbit
      @dvbit For screenOutput? At this moment, Nothing. It is experimental stage. Screenoutput is too tight binded with specific hw. By example, original search results of video is not playable. It is assumed to activate app on smartTv. I had to parse static html output to catch youtube Video Id.
      • Y Offline
        yep_DD
        I switched back to headphone jack output and it is the same. Video and sound stutters.
        • Y Offline
          yep_DD
          @Sean
          Tinker Board looks promising… will take me a while to set up and I am working the next couple of days, let’s see :).
          • Y Offline
            yep_DD
            @Sean I’ve just tried the google voice hat with your module, it works fine and a lot smoothe for some reason. I disabled the BCM soundcard and no stuttering except of the first google assistent replies right after boot up. Still on RPI3, let’s see with tinker board.
            • Y Offline
              yep_DD
              one more thing, I noticed when using the newsfeed module it stutters when fading to the next headline, can anyone confirm that? Performance is 10000x better with TinkerBoard than with PI3
              • Y Offline
                yep_DD
                If anyone is interested, no matter what Board you use the performance is dramatically reduced as soon as you rotate the screen. This is a measurement of PI3:
                • I executed glxgears without vsync.
                • measurements are average of fps
                So without rotation the performance on the pi3 is a lot better. On the Tinkerboard it is even worse as it only supports Open GL ES and I have not found a solution to get that running with Electron.
                • 2 / 4
