    MMM-AssistantMk2 problems when using electron-rebuild
    40 Posts 6 Posters 17.8k Views 6 Watching
    • X Offline
      Xintium
      When I start my magic mirror I get node version error so I did as the instructions told me and tried using electron-rebuild. But when I use electron-rebuild I get this error:
      make: *** Ingen regel för att skapa målet ”Release/obj.target/grpc/deps/grpc/src/cpp/ext/filters/census/grpc_context.o”, som behövs av ”Release/obj.target/libgrpc.a”.  Stannar.
      make: Lämnar katalogen ”/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build”
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:180:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:12)
      gyp ERR! System Linux 4.14.52-v7+
      gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp" "rebuild" "--target=2.0.0" "--arch=arm" "--dist-url=https://atom.io/download/electron" "--build-from-source" "--module_name=grpc_node" "--module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc" "--host=https://node-precompiled-binaries.grpc.io/" "--remote_path={name}/v1.14.0" "--package_name=electron-v2.0-linux-arm-glibc.tar.gz"
      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc
      gyp ERR! node -v v9.11.2
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      Failed with exit code: 1
          at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:277:84)
          at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:242:16)
          at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:201:26)
          at Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:132:26)
          at Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:106:18)
          at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:132:26)
          at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:106:18)
          at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:251:65)
          at SafeSubscriber.__tryOrSetError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:251:16)
          at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:191:27)
      Excuse the Swedish parts.
      What do I do to make it work?
        A Former User @Xintium
        @xintium
        It seems you’ve missed some dependencies or mismatched version (especially node-gyp)
        First, To make things simple, do these before install,
        sudo apt-get update
        sudo apt-get upgrade
        and try rebuilding again.
        If fails, remove whole MMM-AssistantMk2, and resintall from scratch.
        X 1 Reply Last reply Reply Quote 0
        • X Offline
          Xintium @Guest
          @sean should I run
          npm install --save-dev electron-rebuild
          ./node_modules/.bin/electron-rebuild
          In MMM-AssistantMk2 or in MagicMirror directory?
            @xintium
            In MMM-AssistankMk2 directory.
            X 2 Replies Last reply Reply Quote 0
            • X Offline
              Xintium @Guest
              @sean I get the same error as I shared abow
              • X Offline
                Xintium @Guest
                @sean This is what I get when I run magic mirror
                > [email protected] start /home/pi/MagicMirror
                > sh run-start.sh
                Starting MagicMirror: v2.4.1
                Loading config ...
                Loading module helpers ...
                No helper found for module: alert.
                Initializing new module helper ...
                Module helper loaded: updatenotification
                No helper found for module: clock.
                No helper found for module: MMM-darksky-hourly.
                Module helper loaded: MMM-MyCalendar
                WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                Expected directory: electron-v2.0-linux-arm-glibc
                Found: [node-v59-linux-arm-glibc]
                This problem can often be fixed by running "npm rebuild" on the current system
                Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc/grpc_node.node'
                App threw an error during load
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:63:3)
                    at Module._compile (module.js:642:30)
                    at Object.Module._extensions..js (module.js:653:10)
                    at Module.load (module.js:561:32)
                    at tryModuleLoad (module.js:504:12)
                    at Function.Module._load (module.js:496:3)
                    at Module.require (module.js:586:17)
                    at require (internal/module.js:11:18)
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:145:12)
                Whoops! There was an uncaught exception...
                { Error: Failed to load gRPC binary module because it was not installed for the current system
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:145:12) code: 'MODULE_NOT_FOUND' }
                MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                Launching application.
                  @xintium
                  You need module to rebuild.
                  If you tried already, something was wrong so rebuilding process might have been failed.
                  Have you any suspicious messages during your rebuilds?
                  • X Offline
                    Xintium @Guest
                    @sean I get this message when trying to use electron-rebuild
                    gyp ERR! not ok
                      @xintium
                      For confirmation,
                      1. Did you update & upgrade dependencies?
                      2. After that, did you remove MMM-AssistantMk2 directory and reinstall again?
                      Your error shows some of your dependencies are not updated to rebuild.
                      In that case, usually above steps are enough to fix.
                      Maybe this might be a help, but not sure.
                      sudo apt-get install build-essential
                      sudo npm install -g node-gyp
                        logen563
                        Hello!
                        I have this error, when trying to run the node_auth_test.js
                        Error: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21’ not found (required by /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/node-v48-linux-arm-glibc/grpc_node.node)
                        Can you give some advise how to solve this?
                        • 1 / 4
