    ,Change Fonts
    fontraspberry pi 3csscustom
    10 Posts 5 Posters 7.9k Views 5 Watching
    • Lorenzo_ZappaL Offline
      Lorenzo_Zappa
      Hello everyone,
      I know this is a basic question but I wasn’t able to make it :(
      Basically I want to change font in some (or all) modules, so far this is what I have done in my custom.css file:
      @font-face {
              font-family: SF;
              src: url("/home/pi/.fonts/SFProDisplay-Medium.ttf") format("ttf");
              font-weight: normal;
              font-style: medium;
      .newsfeed {
              font-family: SF;
      .compliments {
              font-family: SF;
      .calendar {
              font-family: SF;
      And this is my font permissions in my ~/.fonts folder:
      -rw-r--r-- 1 pi pi 499572 Sep 16 19:29 SFProDisplay-Medium.ttf
      The issue is that whatever font I try it doesn’t work (even standard, already installed, fonts), but instead a default module is loaded…
      Any help?
      Lorenzo
        PhilReis
        Try this:
        @font-face {
          font-family: "MyFont";
          font-style: normal;
          font-weight: 100;
          src:
            local("SF-Pro-Display-Light"),
            url("/fonts/SF-Pro-Display-Light.otf") format("truetype");
        and i have change this too:
        .thin {
          font-weight: 100;
        .light {
          font-weight: 300;
        .regular {
          font-weight: 400;
        .bold {
          font-weight: 700;
        hope it helps.
          Lorenzo_Zappa
          @philreis unfortunately nothing changes…
          Still not working
            PhilReis
            Try to put your fonts directory in the Magic Mirror directory.
            • lavolp3L Offline
              lavolp3 Module Developer
              Better use an absolute path (as you did oiginally) instead of the relative one philreis suggested
              @font-face {
                font-style: normal;
                font-weight: 100;
                src:
                  url("/home/pi/.fonts/SF-Pro-Display-Light.otf") format("truetype");
              The path philreis suggested cannot work as it is.
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
                Lorenzo_Zappa
                Ok, I have found a way to make it work, but I don’t like it very much…
                Basically I have to add my lines of code in this file:
                /home/pi/MagicMirror/fonts/roboto.css
                Like this:
                @font-face {
                  font-family: SF;
                  font-style: normal;
                  font-weight: 100;
                  src:
                    local("SF"),
                    url("SF/SFProDisplay-LightItalic.ttf") format("truetype");
                @font-face {
                  font-family: Roboto;
                  font-style: normal;
                  font-weight: 100;
                  src:
                    local("Roboto Thin"),
                    local("Roboto-Thin"),
                    url("node_modules/roboto-fontface/fonts/roboto/Roboto-Thin.woff2") format("woff2"),
                    url("node_modules/roboto-fontface/fonts/roboto/Roboto-Thin.woff") format("woff"),
                    url("node_modules/roboto-fontface/fonts/roboto/Roboto-Thin.ttf") format("truetype");
                And then everything works.
                Any solution without using this work around? I don’t like it very much, and it is not so clean.
                Thank you
                  Lorenzo_Zappa
                  I finally did it :)
                  I don’t know why but if I want to declare my font-face in my custom.css file the fonts folder containing all my fonts must be in the same directory or in a sub-directory.
                  Now everything works
                  Thank you all guys
                    PhilReis @lavolp3
                    @lavolp3 my solution works.
                    For the web server is the Magic Mirror directory the “root” directory. So you have to create the fonts directory in the Magic Mirror directory.
                    • S sdetweil referenced this topic on
                    • TazDevT Offline
                      TazDev
                      what I inserted in my custom.css
                      :root {
                              --font-primary: "SF-Compact";
                              --font-secondary: "SF-Pro";
                      @font-face {
                        font-family: "SF-Compact";
                        font-style: normal;
                        src:
                          local("SF-Compact"),
                          url("/fonts/SF-Compact.ttf") format("truetype");
                      @font-face {
                        font-family: "SF-Pro";
                        font-style: normal;
                        src:
                          local("SF-Pro"),
                          url("/fonts/SF-Pro.ttf") format("truetype");
                      both files I extracted from my Mac and copied it to ~/MagicMirror/fonts
                        davidgagne @TazDev
                        @TazDev Thanks! This is exactly what I needed to change my MagicMirror so it displays Aurabesh for some of the data.
