    Please help
    29 Posts 6 Posters 19.7k Views 5 Watching
      darrene
      @Moris, when you use the copy (cp) command, I think you have spaces where you shouldn’t.
      if you are in the MagicMirror folder, the command should be;
      cp(space)config/config.js.sample(space)config/config.js
      it is possible to use to auto-complete the text where a file or folder exists if you want to.
      I am not sure why you are getting the Npm ERR! messages. I’m hoping someone else can help here. Are you using npm start on the pi locally or are you SSH’ing into it? I’ve only ever started mine when I am on the Pi itself.
      Edit: @bhepler is a faster typer than me! :)
      your /boot/config.txt should only have =1 and not =:1 for the display_rotate command. Here is an example;
      # For more options and information see
      # http://www.raspberrypi.org/documentation/configuration/config-txt.md
      # Some settings may impact device functionality. See link above for details
      # uncomment if you get no picture on HDMI for a default "safe" mode
      #hdmi_safe=1
      # uncomment this if your display has a black border of unused pixels visible
      # and your display can output without overscan
      #disable_overscan=1
      # uncomment the following to adjust overscan. Use positive numbers if console
      # goes off screen, and negative if there is too much border
      #overscan_left=16
       #overscan_right=16
      #overscan_top=16
      #overscan_bottom=16
      # uncomment to force a console size. By default it will be display's size minus
      # overscan.
      #framebuffer_width=1280
      #framebuffer_height=720
      # uncomment if hdmi display is not detected and composite is being output
      #hdmi_force_hotplug=1
      # uncomment to force a specific HDMI mode (this will force VGA)
      #hdmi_group=1
      #hdmi_mode=1
      # uncomment to force a HDMI mode rather than DVI. This can make audio work in
      # DMT (computer monitor) modes
      #hdmi_drive=2
      # uncomment to increase signal to HDMI, if you have interference, blanking, or
      # no display
      #config_hdmi_boost=4
      # uncomment for composite PAL
      #sdtv_mode=2
      #uncomment to overclock the arm. 700 MHz is the default.
      #arm_freq=800
      # Uncomment some or all of these to enable the optional hardware interfaces
      #dtparam=i2c_arm=on
      #dtparam=i2s=on
      #dtparam=spi=on
      # Uncomment this to enable the lirc-rpi module
      #dtoverlay=lirc-rpi
      # Additional overlays and parameters are documented /boot/overlays/README
      # Enable audio (loads snd_bcm2835)
      dtparam=audio=on
      display_rotate=1
      Hope that helps!
        moris
        This is really fast here with answers. respect. I have no space between config and slash made that is so created when copying from the text. I wrote exactly as you showed it nevertheless, he says there is no folder available. But I see the sample I wrote samaple the whole time maybe this could be the error? Npm start I have with and without ssh tested in the cd MagicMirror and with both the same error. Has what with the config.js to do because it was not?
          moris
          Ok the problem with config.js is allright. I have write samaple the wrong. With sample is korrekt. But npm start have the same problem. Display Rotate. Why the error ?
            leisi
            Uahahha, i´ve the same or a similar problem:
            Hardware: Pi3 with following error, Please help me, whats the problem with my mirror?
            I can´t open the config/config.js file for editing and add. i get this error while npm start:
            (An answer in german would be nice, thanks)
            pi@magicmirror:~/MagicMirror $ git pull
            Already up-to-date.
            pi@magicmirror:~/MagicMirror $ git status
            Auf Branch master
            Ihr Branch ist auf dem selben Stand wie ‘origin/master’.
            nichts zu committen, Arbeitsverzeichnis unverändert
            pi@magicmirror:~/MagicMirror $ cp config/config.js.sample config/config.js
            pi@magicmirror:~/MagicMirror $ npm start
            [email protected] start /home/pi/MagicMirror
            electron js/electron.js
            npm ERR! Linux 4.4.26-v7+
            npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
            npm ERR! node v6.9.1
            npm ERR! npm v3.10.8
            npm ERR! code ELIFECYCLE
            npm ERR! [email protected] start: electron js/electron.js
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the [email protected] start script ‘electron js/electron.js’.
            npm ERR! Make sure you have the latest version of node.js and npm installed.
            npm ERR! If you do, this is most likely a problem with the magicmirror package,
            npm ERR! not with npm itself.
            npm ERR! Tell the author that this fails on your system:
            npm ERR! electron js/electron.js
            npm ERR! You can get information on how to open an issue for this project with:
            npm ERR! npm bugs magicmirror
            npm ERR! Or if that isn’t available, you can get their info via:
            npm ERR! npm owner ls magicmirror
            npm ERR! There is likely additional logging output above.
            npm ERR! Please include the following file with any support request:
            npm ERR! /home/pi/MagicMirror/npm-debug.log
              leisi @leisi
              @leisi said in Please help:
              Already up-to-date.
              Auf Branch master
              npm ERR!
              add. applies my display_rotate file is correct, without the “:”:
              “/boot/config.txt should only have =1 and not =:1 for the display_rotate command.”
                darrene
                have you tried a sudo apt-get update ?
                It might be worth giving that a try - afterwards, reboot then try re-running npm start again
                  leisi @darrene
                  @darrene said in Please help:
                  sudo apt-get update
                  After the sudo apt-get update again i get following error again:
                  (connection via SSH from Mac / my OS is Raspbian Jessie)
                  pi@magicmirror:~ $ cd MagicMirror
                  npm ERR!
                  L KirAsh4K 2 Replies Last reply Reply Quote 0
                    leisi @leisi
                    sudo apt-get update
                    npm ERR!
                    reboot would naturally also done after the update…
                    • KirAsh4K Offline
                      KirAsh4 Moderator @leisi
                      sudo apt-get update
                      I lost count on how many times this has come up already. You can not start the mirror using that command when you are remotely SSHd into the rpi. The rpi simply does not know what monitor to use, yours, or the one connected to it. You have to tell it that:
                      DISPLAY=:0 npm start
                      Use the correct command, and then figure out what the problems are.
                      A Life? Cool! Where can I download one of those from?
                      L 1 Reply Last reply Reply Quote 1
                        leisi @KirAsh4
                        @KirAsh4 oh fucking, yes, you´re right, thanks very much for your help.
                        cowboysdudeC 1 Reply Last reply Reply Quote 0
                        • 3 / 3
