    Independent display controller based on PIR sensor.
    14 Posts 4 Posters 12.3k Views 6 Watching
      shashank @bibi
      @bibi hi can anyone help me with screenshots the file path where to enter the below commands to start it at boot time
      cp ./pir_sensor.service /lib/systemd/system
      systemctl daemon-reload
      systemctl start pir_sensor.service
        bibi @shashank
        @shashank hi! unfortunately you will not find the cmd line in the github to enable the service at boot time. As far as i have checked, the systemd should already run at boot but for strange reasons it was not the case for me. Therefore, i had to issue the command : sudo systemctl enable pir_sensor.service
        good luck!
        • BehB Offline
          Beh
          Ok, maybe I forgot that in the readme file, or it worked straghtaway on my Pi.
          I’m going to add sudo systemctl enable pir_sensor.service to the readme file!
          thanks for the hint :)
            McSorley
            Sounds more effective than mine. I set an infinite loop to check for motion every second and if no motion is detected for 600 seconds the display goes to sleep.
