    MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!
    nestthermostatprotectsmoke detector
    65 Posts 18 Posters 41.5k Views 18 Watching
      costascontis
      isnt updateinterval in ms?cause if it is then 60000 ms = 1min…
      michael5rM 1 Reply Last reply Reply Quote 0
      • michael5rM Offline
        michael5r Module Developer @costascontis
        @costascontis said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
        My bad - you’re right, it’s 1 minute :)
          nhl @costascontis
          @costascontis Make sure the away read permission is active on your nest development OAuth client
            costascontis @nhl
            @nhl in my Other Permissions Away read is greyed out.
              @costascontis It shouldn’t matter - I don’t use the Away read setting in this module. The settings that matter are the ones directly tied to the thermostat and smoke detectors.
                costascontis @michael5r
                @michael5r my Thermostat read is greyed out too …is that matter?
                  @costascontis No, that’s fine - directly below you’ve enabled read/write, so that supersedes the standalone read setting.
                    costascontis
                    found some time to debug why module stops updating.I think it has something to do with my on/off monitor function.I use Motion to turn on my mm tv when movement detected by sending a “/opt/vc/bin/tvservice -p ; sudo chvt 6 ; sudo chvt 7” command.After 5 min with no motion detected it power off my tv sending a “on_event_end /opt/vc/bin/tvservice -p”.I think that after some time of power off monitor the module’s update function breaks.All other modules i use they work and updating fine all the time.
                    EDIT: ignore all of the above,even when my screen is on the module stops updating after a few hours…I dont know what else to try…maybe some other module causing this?Is it possible?
                    EDIT 2: I opened the console at the developers tools inside mm and i notished that from the moment MMM-NEST-STATUS module starts spams with notifications clock and calendar modules like that
                    clock received a module notification: MMM_NEST_STATUS_UPDATE from sender: mmm-nest-status
                    calendar received a module notification: MMM_NEST_STATUS_UPDATE from sender: mmm-nest-status
                    until it stops and stop updating the nest status also.Is that normal?
                      costascontis
                      @michael5r after hours of tests i found out that if i use default clock and calendar module then after a few minutes nest module stop updating.If i dont use clock/calendar and comment them at config.js then nest module is working fine for days.I am not a developer but i suspect that has something to do with notifications between these modules…
                        Yes, that’s totally normal. The mmm-nest-status module is broadcasting a notification to all modules saying that data is available - it’s how the socket notification system works.
                        • 5 / 7
