    MMM-CalendarExt2
    486 Posts 83 Posters 751.7k Views 83 Watching
      gregp @Guest
      @sean Wow! Fantastic! Will give it a whirl.
        dmd @Guest
        @sean “show let’s say 10 markings per week”
        What I meant was that there were two items missing on week 6. Therefore the “+2” like in the screenshot. Fixed it with:
        hideOverflow: true
        “You might have set the position of module itself. MMM-CalendarExt2 doesn’t need position for module itself. remove it from your configuration.”
        Ah, of course. Set position under “views” and now it’s working as desired. Thank you!
          code999
          Great job!
          I was almost done with MMM-CalendarExt then you make it better, now my question is “is there a way to update it to MMM-CalendarExt2”?
          Thanks.
            A Former User @code999
            @code999
            Not upgradable. Both are similar but different from structure to css rules.
              code999
              alright thanks
                fnudd
                First of all, thanks for this module, so far it’s filled all my needs of a calendar. One thing I’m struggling with though is that it seems to redraw itself every minute? And since I’m running MM on a raspberry pi zero the drawing takes something like 3 seconds, which makes it a little irritating. Is there anyway to control the re-drawing? I’ve tried setting the scanInterval, but that doesn’t have any effect.
                I also get some CALEXT2_CALENDAR_MODIFIED notifications at fairly regular intervals, even when my calendar hasn’t been changed, but they don’t seem correlated to the redrawing. I’m only using google calendars, if that’s of any help.
                Thanks again, awesome module!
                  A Former User @fnudd
                  @fnudd
                  https://github.com/eouia/MMM-CalendarExt2/wiki/2e.-Configuration:Others#other-configurations
                  rotateInterval(When you are using multi-scenes) or updateInterval would be an answer.
                  F 1 Reply Last reply Reply Quote 0
                    fnudd @Guest
                    @Sean Look at that, I missed that. So many options:-) Thanks alot, and again, great work!
                      Subintro
                      Hey, so I’ve been using CalendarExt2 for a while for the ‘Current’ calendar feature, but I’m having to move the calendar I use over to private, I have an account with full authorization to view the calendar but when I add
                      	auth: {
                      		user: "[email protected]",
                      		pass: "password",
                      		method: 'basic'
                      to my calendar config, it stops working and kind of causes my whole MagicMirror to crash after a while. The logs show everything loading as normal.
                      My full config is
                      	module: "MMM-CalendarExt2",
                      	calendars : [
                      		scanInterval: 120000,
                      		maxItems: 4,
                      		url: "",
                      		auth: {
                      				user: "",
                      				pass: "",
                      				method: "basic",
                      	views: [
                      		mode: "current",
                      		position: "bottom_center",
                      		calendars: [],
                      		slotTitle: "Current Event",
                       scenes: [
                      		views: [],
                      I do use this with another calendar module, that one works fine with the authentication though.
                      Thank you for the great module otherwise!
                        A Former User @Subintro
                        @Subintro
                        Can you send your ics url and account information? I need those info to examine.
                        If you don’t care, send me by email. ([email protected])
                        • 48
                        • 49
                        • 3 / 49
