    MMM-CalendarExt2
    486 Posts 83 Posters 674.0k Views 83 Watching
      code999
      Great job!
      I was almost done with MMM-CalendarExt then you make it better, now my question is “is there a way to update it to MMM-CalendarExt2”?
      Thanks.
        A Former User @code999
        @code999
        Not upgradable. Both are similar but different from structure to css rules.
          code999
          alright thanks
            fnudd
            First of all, thanks for this module, so far it’s filled all my needs of a calendar. One thing I’m struggling with though is that it seems to redraw itself every minute? And since I’m running MM on a raspberry pi zero the drawing takes something like 3 seconds, which makes it a little irritating. Is there anyway to control the re-drawing? I’ve tried setting the scanInterval, but that doesn’t have any effect.
            I also get some CALEXT2_CALENDAR_MODIFIED notifications at fairly regular intervals, even when my calendar hasn’t been changed, but they don’t seem correlated to the redrawing. I’m only using google calendars, if that’s of any help.
            Thanks again, awesome module!
              A Former User @fnudd
              @fnudd
              https://github.com/eouia/MMM-CalendarExt2/wiki/2e.-Configuration:Others#other-configurations
              rotateInterval(When you are using multi-scenes) or updateInterval would be an answer.
              F 1 Reply Last reply Reply Quote 0
                fnudd @Guest
                @Sean Look at that, I missed that. So many options:-) Thanks alot, and again, great work!
                  Subintro
                  Hey, so I’ve been using CalendarExt2 for a while for the ‘Current’ calendar feature, but I’m having to move the calendar I use over to private, I have an account with full authorization to view the calendar but when I add
                  	auth: {
                  		user: "[email protected]",
                  		pass: "password",
                  		method: 'basic'
                  to my calendar config, it stops working and kind of causes my whole MagicMirror to crash after a while. The logs show everything loading as normal.
                  My full config is
                  	module: "MMM-CalendarExt2",
                  	calendars : [
                  		scanInterval: 120000,
                  		maxItems: 4,
                  		url: "",
                  		auth: {
                  				user: "",
                  				pass: "",
                  				method: "basic",
                  	views: [
                  		mode: "current",
                  		position: "bottom_center",
                  		calendars: [],
                  		slotTitle: "Current Event",
                   scenes: [
                  		views: [],
                  I do use this with another calendar module, that one works fine with the authentication though.
                  Thank you for the great module otherwise!
                    A Former User @Subintro
                    @Subintro
                    Can you send your ics url and account information? I need those info to examine.
                    If you don’t care, send me by email. ([email protected])
                    • W Offline
                      wegz15
                      Hello, I’m having several issues. Im new to coding for the most part. I took a couple basic web design classes about 12 years ago.
                      I was working on my magic mirror for about 12 hours yesterday. The major issue being my events are not loading from my Google calendar. I used it in the standard upcoming holidays module to make sure I was linking it correctly. They show up there, but not in the calenderext2. The other issue is sizing. Its larger than the screen viewing area. I’m sure I’m doing something wrong. I copied the example that was posted in the file and it changes the css look but not the size and events still dont show up. Any help would be appreciated.
                        Subintro @Guest
                        @Sean
                        Damn, I appreciate you trying to take a look but I technically cant due to HIPAA compliance.
                        Have you heard of anyone having any issues with the auth before?
                        • 48
                        • 49
                        • 2 / 49
