    MMM-Globe
    119 Posts 39 Posters 176.4k Views 40 Watching
    • binderthB Offline
      binderth @lolobyte
      @lolobyte said in MMM-Globe:
      only Problem with these images are the white bottomline, on my MM it looks like this:
      0_1483012096329_upload-dda9a5c9-d918-4dc6-b35c-ecf790791bed
      sadly, there’s some white capping down there, but I guess we have to live with that - real time cropping of images won’t make the PIs any faster! ;)
      lolobyteL schlachtkreuzer6S 2 Replies Last reply Reply Quote 0
      • lolobyteL Offline
        lolobyte @binderth
        @binderth
        yes, i know. That’s the south pole. ;-))
        Pull request, good idea.
        The Images are better then nothing.
        I searched for a better view for Europe with full disk, but nothing found.
        Maybe other sources from other user here?
        • schlachtkreuzer6S Offline
          schlachtkreuzer6 @binderth
          @binderth niiiice! :)
            @binderth the globe is cut at south pole area, i think the white slice down there is the background color
            so i think the module cut a circle out of the webpage and down there is some part of the earth missing, or out of view. Also i got another issue: If I´m using the random Photo Module as background, i see a small black border around the full globe. So to fix that, there must be an adjustment for the size of the cutting circle. But anyway the main problem with that white slice is, the image source.
            SvenSommerS 1 Reply Last reply Reply Quote 0
              shgmongohh @binderth
              @binderth
              If I have a bit more time, I’d like to add the standard ones and make a pull request to choose from. There’s a list of (near) real-time images from EUMETSAT: http://oiswww.eumetsat.org/IPPS/html/latestImages.html
              Very nice work!
              It would be awesome, if you could add the real time images!
              Sebastian
              schlachtkreuzer6S 1 Reply Last reply Reply Quote -1
                schlachtkreuzer6 @shgmongohh
                @shgmongohh that would be awesome! thank you in advance :)
                • SvenSommerS Offline
                  SvenSommer @schlachtkreuzer6
                  @schlachtkreuzer6
                  Hey guys,
                  I was able to cut the white bar by cutting the last pixels (depending on the image size) from this image with adding the following to MMM-Globe.js
                  getDom: function () {
                      var wrapper = document.createElement("div");
                      if (this.config.style == "europeDiscNat") {
                  	wrapper.style.height = 0.98 * this.config.imageSize - 1 + "px";
                  	wrapper.style.overflow = "hidden";
                      var image = document.createElement("img");
                  Looking for some building inspiration?
                  Check out my large, thin and metal framed mirror on robstechlog.com.
                  Modules released:
                  MMM-GoogleAnalytics
                  MMM-GrafanaChart
                  MMM-GrafanaGauges
                  schlachtkreuzer6S 1 Reply Last reply Reply Quote 1
                    schlachtkreuzer6 @SvenSommer
                    @SvenSommer Nice work! Thanks. Post it on github as well :)
                      @schlachtkreuzer6
                      done, I also included the sources from binderth and made a pull request.
                      Modules released:
                      MMM-GoogleAnalytics
                      MMM-GrafanaChart
                      MMM-GrafanaGauges
                      LukeCodewalkerL lolobyteL 2 Replies Last reply Reply Quote 1
                      • LukeCodewalkerL Offline
                        LukeCodewalker Module Developer @SvenSommer
                        @SvenSommer
                        could you please adjust the README.md that it contains your additional image-styles? then i will merge your pull request =)
                        thanks for your help improving the module
                        • 11
                        • 12
                        • 3 / 12
